Better results?
Old Nov 6, 2007
baiwldrnner's Avatar
baiwldrnner is an unknown quantity at this point
Better results?
I'm debating whether to add a strut bar and rear sway bar, or change my struts and springs. Which pairing would give better handling results? Thanx.
Old Nov 6, 2007
kuNhoHan's Avatar
kuNhoHan will become famous soon enough
Re: Better results?
depends on your current setup and what direction you would go, if you have stock struts then i suggest upgrading your suspension before you add sways, it is all up to your driving style
Old Nov 6, 2007
AmbulanceMonkee's Avatar
Re: Better results?
i noted a minimal difference with a neuspeed front bar on stock springs and struts, however, the s tech springs and tokico hp struts made a hell of a difference. now that i have all that, i'm collecting parts to add rsx front and rear sways (i dont' have front or rear on my 04 dx right now). which route you choose to go depends on your budget. just remember, if you decide to add a rear sway, you're going to need the progress kit to mount the bar, in addition to the bar and endlinks. i think the progress kit is like 150, plus the bar, and it doesn't include endlinks that i'm aware of.
Old Nov 6, 2007
Re: Better results?
Yeah, my car is bone stock (except for the tires and wheels). I'm gonna track my car for the first time next month, so that's why I ask. I talked to some ppl in my school's car club, and most say a strut bar and rear sway bar is good enough for good track handling. I'm quite unsure. I'll just track my car stock, and then go from there.
Old Nov 6, 2007
kuNhoHan's Avatar
Re: Better results?
thats the best way to go, learn the car from start and work your way up
Old Nov 6, 2007
Zzyzx's Avatar
Autocross Junky
Re: Better results?
Short list of suspension modifications From most important to least.
1. Driver
2. Tires
3. Alignment
4. Dampers
5. Springs & Anti-roll bars
6. Chassis bracing
Start from the top and work down.
Old Nov 6, 2007
Zzyzx's Avatar
Autocross Junky
Re: Better results?
I assume you mean open track?
If so then don't modify any thing. Seriously, get seat time 1st.
Old Nov 6, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
Re: Better results?
as previously stated, hit the track first and find out where your weak points are. learn first, upgrade second.
1. Driver
the more time you spend behind the wheel on the track, the better your car is going to perform. I would only start to upgrade when you get to the point where your lap times are within a second of each other. until that point occurs, you are the only upgrade for your car (and luckily thats the cheapest upgrade)
Old Nov 6, 2007
sl33pyriceboi's Avatar
Re: Better results?
u want a real big difference, get some koni and groundcontrol...
its like driveing a totally differnt car....TOTALLY
Old Nov 6, 2007
twistitup's Avatar
twistitup is an unknown quantity at this point
Re: Better results?
Make sure your tires and fluids are good, (including brakes!) and hit the track. If you've never been before, you are the weakest link of your suspension. (I'm not insulting you it's just learning something new takes practice)
Have fun and learn about your car and yourself!
Personally, the rsx rear sway was a very nice upgrade, and the front strut bar I used helped the front wheels stay more composed. If you decide to modify something and your shocks are still performing well, don't change them, go with the sway and strut combo + alignment. Factory shocks and springs are perfectly fine for performance driving.
It is best to drive fully stock first to see what your car(and you) actually does in extremes.
Old Nov 6, 2007
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
Re: Better results?
I agree with what has been said before me. Im on stock suspension, but I have a neuspeed strut bar. Basically as someone said before it stiffens the whole front end and makes it feel more composed. I really noticed the biggest difference if I encounter roughness in the road mid-corner. Hopefully a track won't have a pothole mid-corner if it's worth a damn, so if your worried about track performance a strut bar would be lower on your list (for track performance).
Old Nov 7, 2007
Re: Better results?
cool! Thanx guys for ur imputs .
Old Nov 7, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
Re: Better results?
For the most effect, this is the order from great to none
sway bars (crappy tires, and youll be losing your back end sometimes)
tires tires tires!!! i cant stress this enough
alignment setting
struts/springs
strut bars
underbrace
etc.etc.
basically if you just do the first 4, you will be fine everytihng else is kinda just a waste IMO
P.S. please remember...negative camber does not equal better handling..."im more lowered than you" also doesnt mean anything
Munzy
21
Oct 7, 2015 07:48 AM
raymondxcho
Sep 29, 2015 09:00 PM
Skunkone
Sep 24, 2015 04:38 PM
Bruce2
Sep 21, 2015 08:01 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
