installing springs/struts
Old Sep 10, 2007
qijian's Avatar
btw... did anyone here not use a spring compressor to install their springs?
if you didn't... enlighten me with your knowledge of how u did it....thanks!
and for others.... how much did it cost to get all the tools to DIY and rent the spring compressor? and where at?
THANKS ALL!
Old Sep 10, 2007
TemjinX2's Avatar
Re: installing springs/struts
you dont need a spring compressor to install aftermarket springs. You need a spring compressor to take off the stock springs because they tend to shoot out when you take off the top mounts.
You can rent a spring compressor for free at autozone.
Old Sep 10, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
you really don't even need a spring compressor anyway. they're civic springs. they're not gonna shoot out like crazy. i've taken struts off civics a handful of times, not a big deal. and if you're scared, just put a jack under it, loosen the mounting bolts up top for the strut, loosen the middle nut, lower the jack, and voila.
Old Sep 10, 2007
or if you really want one, like said above, rent one for free, or they're like 15 bucks at harbor freight.
Old Sep 10, 2007
qijian's Avatar
hah thanks! i guess i'll do that. Also, is there any bump stops to cut while installing the blues w/ my s techs?
Old Sep 10, 2007
i'm pretty sure you only need to trim bump stops when you're using stock struts.
Old Sep 10, 2007
qijian's Avatar
oh, how about with the tokico blues? does that mean theres nothing to trim if i install the s techs with aftermarket struts?
Old Sep 10, 2007
well, no. there's definitely something to trim, but you don't need to. that setup isn't going to lower your car low enough to where you'd need an extra bit of travel. the bumpstop keeps your shock from slamming up against your top mount.
Old Sep 10, 2007
qijian's Avatar
ooohhh i see. so just installing the blues and s techs are fine? and no modifications are needed im assuming?
Old Sep 10, 2007
yep, just install the blues and s-techs, a camber kit, and get an alignment and you're good to go.
Old Sep 10, 2007
qijian's Avatar
so a camber kit is still needed for this drop?
Old Sep 10, 2007
Kevbotron's Avatar
I like my commute
yah, a camber kit is required for any amount of drop, trust me on this one a few blowouts will make you change yer mind..
Old Sep 10, 2007
kcari's Avatar
what do you mean by blow out?
Old Sep 10, 2007
Kevbotron's Avatar
I like my commute
like my tire popped on the highway haha
Old Sep 10, 2007
qijian's Avatar
whoaa. was it due to camber wear? or did u have lots of tread left?
Old Sep 10, 2007
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
^im guessing he meant camber wear... i mean, its just what he was talking about. but who knows
Old Sep 10, 2007
Kevbotron's Avatar
I like my commute
^you are correct good sir
Old Sep 10, 2007
not trying to disagree with kevbotron, but toe is what you really need to worry about. honestly, you might be able to get away without a camber kit with s-techs, but you'll experience a little bit of camber wear over time. honestly though i'd just get a camber kit because there's no sense in cutting corners when modding.
Old Sep 11, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
yea...no need for a compressor if your placing aftermarket springs on...camber kit is a good idea
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
