New suspention= shitty popping...
So before I get started. I have read how you need to line the top hat with the marks. anyways everything was smooth and fine I installed just the front and I believe on my LEFT drivers side it SOMETIMES makes that popping noise that sounds like the spring..
I'm actually going to Canada tonight so I don't have time to fix it. This won't mess anything up will it?
Also how do I fix this. everything is lined up and yeah
Do I need to buy a new bearing for it?
hmm..
Also when I hit some small bumps it hits SO hard.. it sucks.
Currently running...
Tokico Blues
Progress Springs.
hmm..
Tokico Blues
Progress Springs.
Re: New suspention= shitty popping...
don't know, man. failure to properly index the fronts is the most likely cause of what you've described, but if you've done that, i'm outta ideas. good luck.
i had this problem when i had my civic. the problem is that in the honda book, the description of how to install the spring perch and the picture of how to install it were different. im not sure which one i followed, but i ended up putting the perch on 90 deg off of what i was supposed to. the popping only happens when you turn right? at least thats how it was for me. the noise that you are probably hearing is the perch rubbing in the inside of your strut tower. shouldn't be a big deal if you get it fixed in the near future.
Your spring is spinning; it probably didn't sit in right. Mine sometimes does that too, and when I looked at the top mount it was beat up...I have Skunk2 coilovers on stock struts.
if you indexex the top mounts correctly, and it is still making the popping noise like you said, than its probably the top mounts themselves. a typical problem, is people with '02+ civics need to use the top mounts from the '01. the '02+ top mounts uses ball bearings, where as the '01s do not.
Its the upper top mounts on the side its popping on. the top mount isnt applying enough force to the spring, and sometimes it pops under stress of turning. id buy new upper mounts for that side and reinstall it if it keeps on doing that, or first try to tighten the strut bolt (the bolt directly in the center of the mount, visible in the engine bay)
martinsmartin
Aug 15, 2015 07:34 PM
bmoore
Dec 2, 2002 09:01 AM
