Tokico blues and stock springs install help plz!!!
Old Jul 29, 2007
blouisgod's Avatar
Life Begins > 6800rpms
Got some blues for upfront, and Im trying to use the stock springs. I have everything put together correctly but when I try to put the complete unit in, its to long to attach to the spindle and nothing lines up.
I used the spring compressors to try and shorten the unit, but it didnt seem to shrink the unit much at all. What the hell am I doing wrong??? (Using drop springs are so much easier!) I even tried to shrink it using a jack but I couldnt get a safe angle on it!
Old Jul 29, 2007
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
Re: Tokico blues and stock springs install help plz!!!
you need to push down on the control arm
Old Jul 29, 2007
susuking's Avatar
susuking is on a distinguished road
^^^ what he said
Old Jul 29, 2007
blouisgod's Avatar
it seems to be laying all the way down, but ill take a looky. is there any way the axles can pop out? the spindle seems to be extended all the way.
Old Jul 29, 2007
cinaibur's Avatar
you didn't get what i said... when you try to put the whole thing in, you have to push down on the control arm... as you do it... step on it, get someone else to push it or step on it... it takes a little muscle... the control arm rises up an inch or so when you take it out
Old Jul 29, 2007
blouisgod's Avatar
i got what you said, but by pushing the arm down, can the axles pop out?
Old Jul 29, 2007
cinaibur's Avatar
i'm not sure... i'd answer that if i could... all i can say is that it didn't happen to me
Old Jul 29, 2007
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Not a really good idea to put too much pressure on the control arm. You'll be in more trouble if you break it.
Shorten the unit as much as possible by screwing in the 17mm bolt at the top as much as you can. Then get the bottom part of the struts in first, screw one of the 17mm in. Gently push the control arm down, and try to slide the top part in.
Or, you can get the top part in first, hold the unit there by screwing in one or two of the 14mm bolt. Then gently push the control arm down until you can slide in the bottom part. Good luck.
Old Jul 30, 2007
blouisgod's Avatar
sounds good, ill mess with it this week. it was much easier installing drop springs compared to the stockers, ill tell you that.
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
reqy
Jun 1, 2015 07:05 AM
oneheadlight
Apr 29, 2015 11:30 PM
wsking77
Aug 29, 2001 05:34 PM
