Need help with Spring install!
Old Jul 22, 2007
John04Civic's Avatar
John04Civic is an unknown quantity at this point
Question Need help with Spring install!
Well everything went pretty well, but my rear isn't level! My setup is Tokico HP Blues and H&R Sport springs.
I believe it is the camber that is causing it. Check out these pics:
I have NOT had it aligned yet (yes, I know I need it). No shops around here are open until Monday
My question is, will the alignment and adjustment of my camber kit FIX this issue?
Thank you for reading,
John
Old Jul 22, 2007
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
Re: Need help with Spring install!
it's your system... all the weight in the trunk... alignment won't do **** for that... those springs are meant to sit level with the stock weight of the car... not with a system
Old Jul 22, 2007
I didn't think about that! Yet its only 1 12" woofer. Is it really that heavy?
Well I guess then I will get the alignment and get my fender well rolled and call it. I'm not getting rid of my system!
Old Jul 22, 2007
greeen01civic4d's Avatar
good call, i had the same problem, just rolled the fenders and got a camber kit and it solved the problem, just make sure that u get the spc kit, its much better quality, ive had nothing but problems with my ingalls...
Old Jul 22, 2007
I already got a camber kit (cannot remember the brand, it was long ago). It was about $80 to my door from Ebay. I am going to try and get the car aligned Tuesday after I re-index the front right (it is popping / making noise on bumps).
Thanks for the response fellas.
John
Old Jul 22, 2007
burke420's Avatar
The World Is Yours!
take it all out the trunk, and see what it loks like after sitting a while, then add it all back in, then you got the leveled out stance. and if this suspension is new, youll have to wait some time to break-in. my TEINs on my old G35 were the same way... at first it was normal, month later i rear camber bad, with a lil in the front...
Old Jul 22, 2007
burke420's Avatar
The World Is Yours!
roll them fenders too.. itll be worth it if you get any lower due to passengers or weight distribution! camber kit soon! too...
Old Jul 25, 2007
qijian's Avatar
does anyone know how to install a camber kit? or it HAS to be done by pro's? what does "roll" your fenders mean?
Old Jul 25, 2007
camber kit install is easy, its 3 bolts a side, u dont need to have it done by a pro, it takes maybe 20 mins a side, and rolling ur fenders basically means bending the insides of ur fenders(the part that sticks down and inward) and rolling them up, so that the tire doesnt rub, if u dont itll tear up ur tire and fender both
Old Jul 26, 2007
qijian's Avatar
oh i see. thats koo to know. thnx.
im still just stuck with installing camber
if someone could help me out, that'll be wonderful
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
