A simple spring question.
Broad Street Bullies
ive searched everywhere for this and even looked at the official pic drop post. what springs DONT sag in the rear with stock struts and no extra weight in the trunk? ive looked everywhere and it just seems that every spring does it, even if the springs are dropped lower in the front. i know that the front fenderwell is higher than the rear and when the drop is even all around it looks like its sagging, but even with the staggered drops, it still seems to look like its sagging. i will not buy any spring because of this and its really anoying. i just want a moderate drop (i already have SPC front and rear) with stock shocks and no sagging look.
thanks
thanks
Re: A simple spring question.
thanks
thanks
Well if you want a drop with stock shocks/struts you want an unreliable car. Don't cut corners with this. I did with my springs and I totally regret it now. For your wants the best thing would probably be coil overs, because if you don't like the stance, you can easily adjust it.
X2. well said.
Munzy
21
Oct 7, 2015 07:48 AM
