Coilover help
Old Jun 15, 2007
Joshuagwood's Avatar
Joshuagwood is an unknown quantity at this point
Coilover help
I just but a set of adjustable coilovers for my 03' civic si, these are supposed to go right over my factory shocks. My question is do i need a spring decompressor for any reason?? and does anyone know what the rubbers rings are for that came with the kit??
any info would help
-Josh
Old Jun 15, 2007
robbclark1's Avatar
Retired suspension supermod.
Re: Coilover help
It would help if we knew what kind,
Old Jun 15, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
Re: Coilover help
dont really need a spring decompressor, you can just have someone compress the spring with their hands while you take the top hat nut off
Old Jun 16, 2007
robbclark1's Avatar
Re: Coilover help
with sleeved coils, there is no need to push on them. The only time you need a spring compressor or to push on them is with progressive springs.
Old Jun 18, 2007
jamis33's Avatar
You Stay Classy, San Diego
Re: Coilover help
it might be helpful to compress them when taking them apart. It can be dangerous if u dont. Point the hats away from you or someone else.
Old Jun 23, 2007
thatdamndeejay's Avatar
thatdamndeejay will become famous soon enoughthatdamndeejay will become famous soon enough
Re: Coilover help
it all depends on what kinda coilovers you are working with. I just finished putting on my skunk2 coilovers and i didnt need to compress them at all. Then again, my oem shocks blew so i was able to just press down on them and slip the coilover right on. If you use a lift you can just put them on and have them compress themslefs when the car is lowered back down.
Old Jun 25, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Re: Coilover help
The OEM Springs are not under too much pressure but a good way to take apart the strut mount without worrying about it shooting out at you is just lay the assembly on its side on the ground between two wheels/tires and undo it that way.
Old Jun 30, 2007
jamis33's Avatar
Re: Coilover help
thanks for the tip
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
wingsfan19
Oct 1, 2015 03:45 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
