How far can I drive without an allignment?
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I'm getting springs and a camber kit installed at 2 different shops in the city. They're both on the same street but about 2-3 miles from one another. I'm getting Tein S-Tech springs installed at one place, I think they have a 1.6 inch drop, and then going to the other place to have a front and rear camber kit installed. Then after all that I have to get an allignment, but can I drive from one place to the other in between? And also, will I need a front camber kit sitting on 215/35/18 on a DX? They don't have them in right now, it'll take a week to order them. Let me know your thoughts.
Old Apr 3, 2007
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Re: How far can I drive without an allignment?
its best to get an alignment after you have suspension changes because it can be very dangerous for driving especially at high speeds and you can ruin the tread on your tires as well very fast. You don't have to worry too much about getting alignment right away, but just dont drive too much and get the alignment asap. The main concern on the 7th gens is not the camber in the front but in the rear. I'm dropped around 1.7" all around and I do not have a camber kit. I should get one but I am incredibly lazy and broke but my camber doesn't look so bad. but get a camber kit, its better to be safe than sorry
Old Apr 3, 2007
TRIZ's Avatar
Only driving that far away you'll be totaly fine, as long as the instal holds up!! May I suggest DIY for both?
Old Apr 3, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
you'll be fine for sure. I've drove miles and miles with terrible toe and camber. You could always do a little DIY alignment with some string and jackstands if it worries you!
Old Apr 3, 2007
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
I drove 140 miles before I did my alignment. You'll be fine. Don't be surprised when your steering wheel is way off center.
Old Apr 3, 2007
Kevbotron's Avatar
I like my commute
drive like 200 miles before you get an allignment done b/c the springs need time to settle all the way... the allignment will be different if you have it done right off the bat.
Old Apr 3, 2007
TRIZ's Avatar
^^ ahh yes!!
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
Serious?
So should I get the camber kit installed, then the springs.......or the springs then the camber kit? I'm going to try and do it all the same day so I can drive from one shop to the other. And then I should drive for a few days before getting an alignment?
Old Apr 3, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
you can drive for a while without a camber kit, i drove around for a week before i got mine and my tires are fine it was just the steering was off a bit, and high speed driving is fine...formula 1 has negative camber on their cars to help them take corners faster and there going like 200 mph
Old Apr 3, 2007
marcuse's Avatar
marcuse will become famous soon enough
lol... i lowered my car w/ HR sports 1.3 drop on stock struts aboue 6 months ago.. still havent got alignment or camber kit.
Old Apr 3, 2007
Kevbotron's Avatar
I like my commute
Originally Posted by DeX
Serious?
doesn't matter what order... yeah just drive for a few days before you have the alignment done though as like I said... the springs need to settle
Old Apr 3, 2007
Rennen's Avatar
New Mod on the Block
i drove around for about a year before i got a lifetime alignment on my car... now i get it done every couple months.
Old Apr 3, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Camber isnt a big deal. Toe is what you have to watch out for. You pay alot for your tires so why not make them last. If you modify your suspension like that your camber and toe will be off a good bit, it doesn't take long for your tires to get worn.
BS on the waiting for a week to align, the settling will not change it that much of a difference.
Go get that **** aligned before you make another thread about where to buy new tires.
Old Apr 3, 2007
blackonblack's Avatar
blackonblack has a spectacular aura aboutblackonblack has a spectacular aura about
i am gonna have to disagree with your comment. last summer i dropped my civic on sportlines and decided that i was "too lazy" to get a camber kit. well when i took my wheels off for the winter both front tires were gone, and i mean gone. my tires were as soft as bubble gum. BUT my rear tires were not in that bad of shape. actually there was little tire wear at all. different suspension set ups will result in different levels of wear on your tires. moral of the story --> get a camber kit and get an alignment once your drop has settled.
Old Apr 3, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
You can drive as far as your tires will let you, then when they wear out at crazy angles you can get new ones and drive some more! till eventually you get so tired of it you decided to align it and drive some more!
Old Apr 3, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
im running 500+ miles strong dropped on stechs! oh yea!! but im getting my tires put on and alignment 2moro morning. dropping ur car gives u negative camber, so if anything ur gona handle better!
Old Apr 3, 2007
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
ive done maybe 30,000 kms without one my tires r still fine...
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
Okay, so you think I'd need a camber kit for the front or just the rear would be fine?
Old Apr 3, 2007
metalviper's Avatar
well do u really wana go with OEM specs?
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
What does that mean?
Old Apr 3, 2007
Kevbotron's Avatar
I like my commute
"OEM specs" is an allignment w/ a stock camber arm or bolt. You will never get a proper allignment on a lowered car w/ stock camber bolts and arms... I would get front and rear to avoid the headache down the road even though the rear gets worse wear than the front
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
Okay, I'll get the springs, then drive over and get the camber kit front and rear, then get an alignment at the same place. Thanks.
Old Apr 3, 2007
right on dude. made the right choice.
Old Apr 3, 2007
DeX's Avatar
DeX
Canadian, Eh!
Last question, would you suggest Tein or Intrax? The Intrax are regularly $290 while the Tein are regularly $205. But I can get the Intrax on sale for $180.
Old Apr 3, 2007
metalviper's Avatar
for just the springs...i like my stechs. they are great for a dd. idk anything about those intrax so ya...
Old Apr 4, 2007
never heard of intrax..
Old Apr 4, 2007
waddle313's Avatar
waddle313 is an unknown quantity at this point
when i put springs only on my car, eibach pro spring, i drove about 10,000 miles before i got an alignment. tires were good didn't even need the alignment when i decided to get it! just depends on how low you go.
Old Apr 4, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
I'm surprised nobody has asked why you are getting your springs and camber kits installed at different places. To install the springs you have to take the shocks/struts off (by removing the camber bolt/arms) and then reinstall everything. Why not install the new camber kit when reinstalling the shocks/struts?
Old Apr 4, 2007
DeX's Avatar
DeX
Canadian, Eh!
It's $100 cheaper to install the camber kit somewhere else. They also carry a different cheaper camber kit I'm getting.
Old Apr 4, 2007
civicvtec1ps's Avatar
Search and Learn
Spring install can be pain in the ***.
But save money and do camber kit install at home!
6 bolts to remove on rear.
Front camber bolt is useless, it tends to move around and mess up spec anyways.
As long as alignment shop can set toe at 0, it should be fine.
I think i've driven my car without alignment done for maybe 6 months.
(No camber kit, 2 inch drop.
