How far can I drive without an allignment?
Canadian, Eh!
Re: How far can I drive without an allignment?
No worries, I called today to order the springs from Speedtech for $230 and $200 installed. Then CMS to order the camber kit for $200 and $200 installed. But as I was talking to them, I found out Speedtech will only charge $220 for the camber kit install AND the spring install if done at the same time. so I just went with the more expensive Eibach camber kit from Speedtech and ended up saving $100. So it's all being done at the same place now, and the guys there suggested that I drive it for a few days to let the springs settle before doing the alignment.
okay...for the most part everyone is wrong...ive been doing alignments at my job for 2 years. camber IS a big deal. especially when you are lowered. i HIGHLY recommend an adjustable camber kit. driving a couple miles is NOT a big deal between installs. HOWEVER! DO NOT drive for any longer than that. when you lower a vehicle and install aftermarket adjustment kits the alignment is completely out of whack! i recommend getting an alignment policy immediately after the installs to correct any alignment issues. ALSO! VERY IMPORTANT! the tech. installing the adjustment kit should somewhat "eyeball" the alignment before setting the car down on the ground. yes the springs take a while to settle but that is why i say get an alignment policy (i.e. 1yr, 3yr, 5yr, etc) this way you can return at anytime and have the alignment checked and done. TRUST ME!
true if u really dont trust urself to install the springs (which looks harder than it really is) then at least put the camber kit on b4 u have the springs installed. its quick, easy, and ud save money please....do not get owned on the camber kit!
interesting thread .. i just installed a new set of tokico hp's with eibach sportlines the other day. I already had an spc rear camber kit from my other springs, the prokit. When I took it for an alignment the first time, they printed out a sheet with the specs and told me they didn't need front camber bolts. With the sportlines I did though, and aparently without them they told me it would've been impossible to get the steering right!
Yes Sportline is made by Eibach. Its what I have as well, im very excited to be putting them in once I get my koni yellows.
Worry about toe more than camber.. Just save the money and buy it all at once its worth it. I have the SPC camber kit on my car, and I am not even dropped yet, Its the first thing I do before I even think about lowering.
Aren't alignments only 30-60$ ??? Why would you want to drive without an alignment? Not only is it dangerous, but its pretty damn annoying too.
BlackonBlack's got it right. Camber kit is very easy to install, you just need a good wrench. Its just 3 bolts. Lift your car, take the tire off, and find the stock camber, take it off, then adjust the spc camber to the stock camber length by turning it, bolt it in.. done.
Front bolts are even easier.
Its not hard at all. I wouldn't do springs by myself though.
Canadian, Eh!
I was told by the shop that the front camber bolts on my car only correct for 1 degree of camber so he said not to bother.
ley--> springs are pretty easy as well dude. if you follow the DIY on this site you should have no problems at all.
Dex--> the front camber bolts cost like $20 so why not just be safe? at least that's what i think
Canadian, Eh!
Wow, this keeps getting better. The shop phoned me telling me my Eibach camber kit is in, that's awesome. Now I'll call them up and get the $220 quoted install for everything right? Wrong. The guy says ya, it's $220 but if any of the rear bolts are seized it'll be another $120 for 1.5 hours of labour and the cost of a new bolt. I'm like, "......ummmmmm........no........." so I tell him that's ridiculous and hang up. Thanks to Grey's D.I.Y. and some other members for coaxing me into it, I just finished installing my springs and camber kit myself. It wasn't really that hard though I wish I did have an air gun. And with the money I saved, I picked up a sweet jack and 2 jack stands. Plus put some in my pocket. So far I think the only thing I paid anyone else to put on my car is the pager alarm system, it feels good.
*EDIT - ....and tint.
I just installed tein SS in my 05civic sedan.. i raised it up a little so it has a little less than a two finger gap..the camber doens't look to bad..but its ok to only get the rear one?...i read on the post early that its more important for our rear ones..but should i get a front one too with the rear or could i wait awhile before i grab the front ones? cuz i'm sort of low on money since i got the SS
btw i agree with viper...lets see the pics!
Canadian, Eh!
The front camber kit is just 2 bolts and it's only $30 or so. But yes, you can wait because the kit only corrects for 1 degree of camber. I'll get mine eventually.
Xuhme
21
Aug 7, 2023 03:40 PM
trellex
May 24, 2015 04:39 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
