Question about full coilover
Old Mar 10, 2007
Backman's Avatar
Backman is an unknown quantity at this point
I read a lot from this forum section but did not found something that answer to the following question :
A camber kit is needed in order to correct the alignment of wheels in case of drop. I think this is clear, that's not my question
So, what about true coilovers that allow to adjust the ride height on the fly?
Is the wheels alignement is modified each time an adjustement is done on the coilover?
I'm looking for changing all my suspensions witch is stock and really tired... And I'm not expert as you see and I would like to find something that will be bolt on without any special fitting need to be done like It seem to be the case for the koni strut.
Basically I'm looking for something very strong and that will allow a reasonable drop.
Any suggestions?
Thanks!
Old Mar 10, 2007
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Every time you adjust the height you will need to adjust the camber to compensate. I Highly recommend a nice set of struts and some lowering spring. Full coil overs are nice but if you don't have the experience in setting them up they can be a pain, there are like a couple thousand different setups you can do with full coil overs because they are so adjustable. thousands of possibilities can = a lot of bad setups. If you want something simple and good I would go for a set of Tokico struts and some lowering springs you don't have to do all sorts of modifying and cutting with the Tokico's like you do on the koni's. I just got a set of Tokico D-spec's with adjustable dampening and a set of progress lowering springs (2in drop in the back and 1.8 in the front) from Paul at Dezod. There awesome, easy to use and pretty easy to install if you have any mechanical experience, and you don't have to cut up your old struts like the koni's
Old Mar 10, 2007
dk1021's Avatar
dk1021 is an unknown quantity at this point
Yes, wheel alignments will be off each time height is adjusted. Therefore need to go for an alignment after height has been adjusted. For me, i adjust it twice a year (Spring / Winter) cause of snow, etc. Alignment shops should be able to adjust camber for you as well since it'll be affected as well. Good luck!
Old Mar 11, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
camber is the main thing that is adjusted when getting an alignment. toe and caster are also adjusted during alignment but caster usually is a lot harder to adjust especially on these civics. the more u drop ur car the more negative camber u have. so if u dont want to have to deal with adjustments just get shocks and springs. IMO and from suggestions, anytime u mess with suspension u should get an alignment
Old Mar 11, 2007
Backman's Avatar
Ok thanks! That's what I was thinking. It's not right for me...
Now I'm hesitate between KYB AGX and Tokico D-Spec.
And Tein S.Tech or Neuspeed Sports...
Finally a SPC camber kit #60090
Am I forgetting something?
Old Mar 11, 2007
robbclark1's Avatar
Retired suspension supermod.
Nope, and just pick one...there really isn't gonna be much difference between those set ups.
Old Mar 11, 2007
Backman's Avatar
Excellent!
Thanks.
Old Mar 13, 2007
Backman's Avatar
Is this could be a fair deal?
http://cgi.ebay.ca/KYB-AGX-STRUTS-SH...paymentmethods
Old Mar 14, 2007
robbclark1's Avatar
looks good to me. Not many people have vogtland, but they are reputable.
Old Mar 14, 2007
Backman's Avatar
Are those shocks "bolt-on" my oem struts?
Old Mar 14, 2007
RHCP0801's Avatar
just make sure you get 14mm struts not 16mm, 01-02 struts are 14mm and 03-04 struts are 16mm
Old Mar 14, 2007
RHCP0801's Avatar
what do you mean by this?
Old Mar 14, 2007
Backman's Avatar
I'm wondering if the strut needs to be modified as it is the case with Koni shocks?
Old Mar 20, 2007
Backman's Avatar
Re: Question about full coilover
No one have installed KYB AGX shocks in OEM struts?
Old Mar 20, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
its a whole strut. Only Koni does whack a strut
Old Mar 21, 2007
Backman's Avatar
So this is an error ?
http://www.1motormart.com/unified/bu...ke_code=HO&x=1
vs
239$ vs 185$ for the front left
Old Mar 22, 2007
TRIZ's Avatar
What coilovers adjust ride height? I think you misread some descriptions, and dampening is what can be adjusted "on the fly." ...meaning u can change the rebound rate of the strut whenever u want. For this, you dont need a camber adjustment.
Old Mar 22, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I don't know if it's been mentioned yet, but our cars also have Mcpherson struts so with the proper coilovers, you won't need a camber kit for the front. It's built into the suspension. The only adjustment will be in the rear so you should be able to change on the fly without too much trouble.
Old Mar 22, 2007
Backman's Avatar
I think you're wrong.
If not, someone have to explain me the purpose of the tool in the bottom of this picture :
Old Mar 22, 2007
Backman's Avatar
Anyone could confirm that?
Old Mar 23, 2007
DeX's Avatar
DeX
Canadian, Eh!
I know this 100%, I was talking to a guy at Speedtech (reputable performance shop in Calgary) about the Tein coilovers and they make a Mcpherson coilover kit for our vehicle for that purpose. Check Google. I'll see if I can find pictures.
Old Mar 23, 2007
DeX's Avatar
DeX
Canadian, Eh!
Notice the mount on top of this kit.
Notice it's missing on this kit.
Old Apr 3, 2007
JeesunUltra's Avatar
JeesunUltra is an unknown quantity at this point
there are only two things i hate with my coilover.
- takes time to even out the ride height (removing the tires, putting them back on, checking the height of the left side against the right side, height on the front side to the back side)
- wheel alignment is needed after significant change in ride height (toe and camber)
Old Apr 3, 2007
metalviper's Avatar
i think he means if u get a camber plate with the coilovers then u can adjust the camber at the strut top i think...
Old Apr 4, 2007
^ works for the front. you'll need another camber kit for the rear.
just make sure that you do not slice the camber plate when you adjust it. tein's camber plate is soft.
Old Apr 4, 2007
robbclark1's Avatar
That is common with ALL suspensions. You can hate it all you want, but it is built into almost all production cars.
Old Apr 5, 2007
^ patience is i need. lol
GolNat
Jul 15, 2015 03:42 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
viper775
Dec 9, 2001 10:52 PM
artychris
Dec 7, 2001 02:01 PM
duyaknow
Nov 23, 2001 07:28 PM
