How good is this setup I just got,
Old Feb 2, 2007
dblclutchin's Avatar
dblclutchin is an unknown quantity at this point
Thanx to member hauliau I just got hooked up with some Tokico HP's and some S-Techs for a good price lowering my guess 1.5" I just wanna know how well this will handle, ride comfort and just any other feedback you can give me for this setup. Thanx
Old Feb 2, 2007
chicohonda02's Avatar
Since 2002 Baby!
sound sweet, let us know how it works out.
Old Feb 2, 2007
eye_see_you's Avatar
let the devil out
I had almost the same setup when I had my civic its a rather nice ride
Old Feb 2, 2007
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
a very nice ride comfort i'd say.. my friend (susuking 7thgener) has exact same setup and i rode it. its really nice when it comes to comfort. its 10 but the height is alittle high.
Old Feb 2, 2007
Kevbotron's Avatar
I like my commute
I will be on a similar setup once I put MY newly acquired blues on (blues and Prokit) I'll let you know how much different it feels. I hear good things about HP's tho
Old Feb 2, 2007
tougEMII's Avatar
tougEMII has a spectacular aura abouttougEMII has a spectacular aura about
with hp's. should feel like an oem ride but a lil more stiffer. =D
Old Feb 2, 2007
Zzyzx's Avatar
Autocross Junky
Its a good start for a street setup.
my advice; Make sure you pick up a camber kit front and rear, as the sooner you can get away from the OEM alignment the sooner your car will handle better.
Old Feb 3, 2007
I'm not going to put on a camber kit right away and I just plan on having an alignment from the shop. My bad??? I read the stick sayin im going to be pimp slapped if I ask if I need a camber kit but......Do I? I heard in most cases you can get away with not having one if the drop is moderate. I think this will only be like a 1.5" drop....
Old Feb 3, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
i just put on my blues and s-techs a couple days ago. the ride is like stock just stiffer. my springs havent settled all the way yet but i like the drop. im using an spc camber kit with specs of -1.25 front, and -.75 rear as recommended by someone on this forum. well at least thats the specs i will use when i get it aligned. its not bad, but u can see the neg camber and id rather not wear my tires. so id recommend a camber kit.
Old Feb 3, 2007
Coloraduh_Civic's Avatar
Coloraduh_Civic is an unknown quantity at this point
You'll need a camber kit. I have the same setup your getting and I NEEDED one. Look into spc.
Old Feb 3, 2007
Did you not get one right away or did you just get regular alignment? What kind of preoblems did you have?
Old Feb 3, 2007
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
Howstuffworks "How Tires Work"
Old Feb 3, 2007
miklovo's Avatar
miklovo is an unknown quantity at this point
Get a camber kit, unless you don't like your tires. When I had my Pro kit on (only a 1" drop) after a year the insides of my tires were done. I wanted to get new tires anyway so no biggie, but when I switched to the H&R kit I did front and rear cambers....
Think of it this way, you'll spend $250 on a camber kit but you'll spend maybe $800 on a new set of tires in a year
Old Feb 3, 2007
TeLLy's Avatar
Yes, it's an Acura EL
No offense intended, but shouldn't you be asking this sort of question BEFORE you put the money down? Retro-researching is usually not very productive cause if you find out your stuff is crap you have to go through the trouble of taking it back or you install it anyway and have the thought "This stuff sucks" going through your head every time you drive.
But back on topic, it's a nice setup.
Old Feb 3, 2007
acidbaby's Avatar
The Beez Kneez
shouldn't you have posted before you bought them?
"how good is this setup im thinkming about buying?"
Old Feb 3, 2007
metalviper's Avatar
really? $250? i bought an spc camber kit for less than 80 bucks
Old Feb 3, 2007
phuviano's Avatar
Slowest 7thgen in the GTA
Its better to get a camber kit to be on the safe side. I only have a rear camber kit on my car. I'm dropped 1.75 in the front, and I have even tire wear in the front. Whatever you do, get an alignment after you lower your car.
Old Feb 3, 2007
you cant align the car once its lowered without a camber kit
Old Feb 4, 2007
phuviano's Avatar
sure you can, you don't need a camber kit to get an alignement.
So you're saying all those people driving stock cars can't get an alignment, if their camber,or toe is off, they can't get it aligned???
so stock 7thgens without a camber kits can't get alignments??
Old Feb 4, 2007
sl33pyriceboi's Avatar
he means get an alignement that is within OE specks when ur dropped with such springs........
lol........hes not THAT stupid you know, its very well repp.ed and knowledgeable on this forum.....
heck, hes even got a DIY alignement thread or soemthing....ahah
Old Feb 5, 2007
Zzyzx's Avatar
Autocross Junky
You may not technically need a camber kit to get your car aligned to the OEM specs.... but you should want a camber kit so you can specifically get away from the Craptacular OEM alignment specs.
Old Feb 5, 2007
Is there a DIY on adjusting the rear camber to get good specs and what exactally are ideal specs? If I algin it myself I still have to go and have a shop do alignment right? <------- Noob sorry bout the obvious questions.
Old Feb 5, 2007
miklovo's Avatar
Wow, I paid excatly $224.00 for mine front and back set with the install + lifetime warranty and alignment. Thats what I get when I don't want to install it myself i guess!
Old Feb 5, 2007
Zzyzx's Avatar
Autocross Junky
Ideal would depend on your intended application and what tires you are running, among other things.
But, for a street driven car....
-1 to -1.5 deg camber on the nose, 0 Toe.
-.25 to -.5 Deg camber on the rear, Maybe 1/32nd total toe in (Thats 1/64th toe in per side)
It may not be "optimum" but its a good start, and a whole lot better then the OEM alignment.
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
