isntallng camber bolts
Ashho-san 7thgen Ninja
does anyone have a diy for installing the front camber bolts? and also, as a matter of opinion, woudl it be worth while for me totry this or should ijust ake ti somewhere and have them installed and the camber aligned trogether?
I need TP for my bunghole
The install is easy; but the alignment without the proper tools or know how would be a pain. I would take it somewhere and have them do it.
Sears will guarntee the alignment for 6 months. so if it feels weird they will do the whole alignment again for free!
a god send for a lowered car! bar none!
take old bolt out, put new bolt in, roll to alignment center, get alignment, roll out
If you pay them to install a bolt, I will personally kick your ***.
lmao alright, sounds easy enough. nother question though. i noticed that with the 01-02s there were options on either a 14mm or 16mm bolt. with the neuspeed sport drop, is the 14mm bolt the appropriate one, or should i have gotten the 16s?
Edit: Also, thsi question may be a little late in coming, but which bolt do i replace?
it comes with directions. for someone with almost 1000 posts you sure are pretty noob. i searched and found it on the first page. remove the top bolts. replace the bolts. DONE. its not hard. the rear camber kit is 3 bolts. undo 3 bolts, take the upper control arm off, replace it with your new one, put the 3 bolts on. SPC has the ENTIRE diy on their site. at least try to look for it.
for all ur sarcasm that was the most helpful response ive gotten so far. thanks. Do you know if i should have gone with the 14mm or 16mm bolts for a neuspeed sport drop?
O and when you buy them second hand they dont come with directions
lol sorry. but yeah. here il try to link you to SPC site. the intructions are there.
http://www.spcperformance.com/PerfTe...rojHon1_E.html
REAR ALIGNMENT and FRONT ALIGNMENT. shows you step by step. rep please
lol.
its not really a step by step but it is very informative, im sure you will be able to do it with that.
edit: heres some more useful info for you.
http://www.spcperformance.com/PerfPa...art_EZCam.html
lol.its not really a step by step but it is very informative, im sure you will be able to do it with that.
Dave Brabant
20
Oct 6, 2015 12:44 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
