who makes strut mounts for our cars?
Subscribe
Nov 7, 2006
I have this creaking noise when i turn my wheel all the way to the left. the driver's side spring/strut assembly goes kreeeek and then i swing it back to the right and it goes pop pop. i read the sticky but doesnt help me because honda installed this, honda said they recommend urethane strut mounts.. but idk who makes those and if they are even available, one of the mechanics said that the 03-05 has bearings which i saw and he said its a good design just poorly done from honda, whatever the heLL that means. Anyways who makes strut mounts for our cars? im taking it back to honda saturday for the alignment, mount and balance and to check the assembly again. i have the tokico HP and Tein S.Tech setup
Reply 0
Nov 8, 2006
If it was not making that noise before you installed the suspension, they probably installed it incorrectly. Only thing you can do is tell them to redo it because they messed up.
Other than that... you might want to upgrade to 03-05 strut mounts assuming ur car is an 01-02.
Reply 0
Nov 13, 2006
05 civic ex. wuts bad bout the 01-02 mounts?
Reply 0
Subscribe
