Sitting on TeinSS for a EP3-R
Old Oct 16, 2006
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Sup all,
Well i got my Tein saterday all excited but this tein that arrived was for the
type R in japan, so started to do some messuring look to my that they would
fit.
So went to my friends shop and tried if they would fit.The rears are bolt on...
the front to but the spring seal was just compressed against the rubber
bearing,So you will have to make the dia size smaller so from the outside so
it will slide in the rubber bearing a little.Then i cant move in everyway.
Neg site of this site is the hight adjust range. i dropped it all the way and
still got 3finger gap in the front.BUT the car is sticking on the road realy and
you can do a hell of cornering.
Like some suspension guru says to change thier front sway from 21mm to
15.9 mm realy understreer is gone. the rear i got the 19mm rsx sway it
makes the *** just follow the front wen yo go even faster the car strats to slide on the 4 wheel what is realy nice. i like how you can control that slide.
For those some nfo about it
Part nr QSA12-AVSS2
Ride drop Ft:-20 Rr: -5
Spring Rate Ft: 5Kg(280) Rr: 9kg(504)
Ride hight range Min/Max Ft: -3 -> -10 Rr: 13 -> -24
Sorry if thiers bad englisch or typos dont use to write it everyday so...
will post op some pics later on still testing setups...
peace
Old Oct 16, 2006
burke420's Avatar
The World Is Yours!
good thing i read the exclusion at the bottom, maybe the type r are heavier in the front, since you have a k20a3 a assume, and the other is a K20aR. the type r's have a wiser stance if im not mistaken as well too!
Old Oct 16, 2006
DaRk_MauL's Avatar
oh my bad i forgot to say that they fit my 04Em2.
Old Oct 16, 2006
susuking's Avatar
susuking is on a distinguished road
uh great~
Old Oct 17, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
so you put ep3-r Tein SS on your 04 em2? you said something about the rubber bushing/bearing up front....is it rubbing or a tight fit? i'm not quite sure i understood your meaning....
Old Oct 17, 2006
DaRk_MauL's Avatar
ill post pic today or tomorrow so you will see what i mean.
nirvanaguy
25
Oct 26, 2017 07:26 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Styven Szastur
Sep 23, 2015 05:26 PM
Mannimarco
Sep 7, 2015 10:01 PM
tommycanada
Sep 5, 2015 04:59 PM
