help! spring problems
Old Oct 10, 2006
CASPER087's Avatar
People point and laugh when I drive by. Plus I like men.
CASPER087 is an unknown quantity at this point
hey i was just wondering if springs would ever stop popping. i put tein springs on my stock suspension (i know i should have gotten the struts and all but i didnt) but since i had them on they still havent stopped popping. is it just the springs wont settle or still not settled yet or is it a problem. its when ever i turn my wheel to the left or right alot. if i put wd-40 on my struts then it stops for a while but other then that it wont stop popping. can someone please help!
Old Oct 11, 2006
burke420's Avatar
The World Is Yours!
sounds like you didnt replturn the strut mount to the proper position...it could be moving in its place, or the spring isnt seated properly snug on the perch itself. also.. spring could be letteing the suspension bottom out on bumps...therefore...your bumpstop need to be replaced. or put back on. i didnt have any when i dropped my car with coil...and it was a rough ride for a couple weeks..then i bought new one from Honda...trimmed them...now good! but a small popping is still coming from my strut mount... since i removed the strut mount with the bearings. i just lube it up with a super slick grease monthly. try these out...should fix it.....
Old Oct 11, 2006
CASPER087's Avatar
yea i greased it up i think im gonna start doing it alot to see if it eliminates the pop completely. i dont feel like taking apart the suspension again to eliminate the pop but ill keep trying to fix it. its just so annoying hearing that pop. do you know why my exhaust is squeeling like when im at a stop it sound like a little wierd squeel like my exhaust is barely touching my body kit or something i dont know what it is though
Old Oct 11, 2006
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
When I was searching for info about spring wraps I came across alot of spring popping threads like the one you are describing. hint hint bold
Old Oct 11, 2006
03logic's Avatar
03logic is an unknown quantity at this point
i'd put money on your struts not being re-assembled correctly. you have to line them up the way that you took them apart. take your front shocks back off, take them apart, then line up the arrows on the top of the shock. then where those arrows are at, line them up with the part that faces outward, not sure what that arm is called, but thats what you line them up with. This problem is common with spring installs.
Old Oct 11, 2006
CASPER087's Avatar
is there anything bad that could happen from it or just you hear popping?
Old Oct 11, 2006
kuNhoHan's Avatar
kuNhoHan will become famous soon enough
easy ... mis-installed springs on stock struts ... bye bye struts sooner than later
Old Oct 11, 2006
CASPER087's Avatar
so you think there gonna blow out just sooner? i was planning on getting new shocks and struts soon anyway. any recomendations on what kind of shocks and struts and where to get them from?
Old Oct 11, 2006
03logic's Avatar
they will blow, yes, or be damaged in some other way, but you could also cause damage to more than just ur shocks (your springs, other suspension components, other car components). check around the for sale threads for aftermarket shocks. you could also look at some reputable online dealers, like some of the 7thgencivic.com sponsors.
Old Oct 11, 2006
CASPER087's Avatar
iight thanks how much do you think shocks and struts would cost for the aftermarket. for some descent ones
Old Oct 11, 2006
03logic's Avatar
tein is a solid route that a lot of people go, i use tein springs on my car and love them. the tein basics are a good choice, you can get them for around $800. if your not looking to spend that much, just get tokico blues for around $400.
in the end, make sure you research what you put on your car so you know what you are getting.
Old Oct 11, 2006
CASPER087's Avatar
i have tein springs on my car now on factory struts. so do both of those include struts and shocks or what should i get? im not to good on knowing things about suspensions. i helped do mine but thats one thing i dont know to much about i need to learn about more though.
Old Oct 12, 2006
03logic's Avatar
struts and shocks are the same thing. you would be fine just getting the shocks since you already have springs, cheaper way would be tokicos, more expensive would be koni sports, tokico d specs, or some other springless shock deal.
just dont go cheap, you really do get what you pay for.
Old Oct 12, 2006
CASPER087's Avatar
so getting the struts and shocks would cost 400 for the tokico blues? i mean are they that bad that i shouldnt get them at all?
Old Oct 12, 2006
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Like 03logic said struts and shocks are the same thing. Tokico blues will be fine. Many people have them and are happy with them.
Old Oct 12, 2006
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
Do this installation right the first time...i dont have to tell you the headache...unless you are dumb..
ebay sells tokico blue for less than $400...bought mine at $329...all four
dont mind about struts and/or shocks...like '03logic' said same thing...damper
reqy
Jun 1, 2015 07:05 AM
vtec_concept
May 24, 2015 10:27 AM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
Flatlander
Nov 16, 2001 05:38 PM
