URGENT HELP!!! Rear Shocks Won't Install
Old Aug 21, 2006
PrYnCeQT's Avatar
PrYnCeQT is an unknown quantity at this point
I am doing the DIY on spring install right now and I got the front in with not too much problems but now I'm on the rear shocks and springs and I got the whole piece put together correctly but I the shocks are too long and even when I screw the whole top in as much as the tread would take me, I can't get the holes on the bottom part to line up. The DIY just says to reverse the steps, but fails to mention this part and seems like no one else had this prob as I just read all the pages. Do you guys who have done it always have the holes on the bottom to line up? How did you guys do it? I'm on Tein S-Techs and Tokico Blues. I was on stock springs before and they are longer then the Teins yet there were on there before and was easy to come off. HELP HELP HELP!!!
Old Aug 21, 2006
tuner04civic's Avatar
spell check pwns you
did you use a spring compressor?
Old Aug 21, 2006
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
I had this problem when I installed my Bilsteins. I had to use a large impact socket on a jack to compress the shock enough to get it in place. insert something (a phillip screwdrier will do) to align the hole. The longer the screwdriver the more leverage you will have to force the holes to align. When aligned, insert the bolt. BE VERY CAREFUL when compressing the shock with the jack, any misalignment, the socket will snap and shoot out with great force. The larger the socket the more stable it will be. Either way, it's a bitch to get the holes to align. Good luck!
Old Aug 21, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
make sure you dont have the spring upside down.
Old Aug 21, 2006
blackonblack's Avatar
blackonblack has a spectacular aura aboutblackonblack has a spectacular aura about
dude did you step down on the trailing arm when you tried to re-install the shocks? if not try that and see if that will work for you.
Old Aug 21, 2006
CenZ's Avatar
PWIT
yeah get someone around 180+lbs to stand on the drum as you slide the bottom bolt in. its simple. i was havin that problem too.
Old Aug 21, 2006
ya that stumped me as well. i think that will solve the problem.
Old Aug 21, 2006
PrYnCeQT's Avatar
Thanks guys, I actually used EX4Dr's method before I just read his post. Was quite easy after that. But man, some info on that really needs to be put in the big DIY thread.
blackonblack, I'm not sure what the trailing arm you are referring to.
CenZ, I'm not sure 180+ is a good idea on standing on the drum.
Old Aug 21, 2006
CenZ's Avatar
PWIT
i did it on 2 installs. i tried my gf who is 110lbs and it didnt even move, so im 180lbs and it moved enough, i accually had to jump alittle for her to get the bolt in.
Old Aug 24, 2006
doesn't matter much if you got it to work dude
Old Aug 24, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
i hammered the bottom of the strut until it lined up and have someone put weight on the control arm/knuckle
Old Aug 25, 2006
RHCP0801's Avatar
i weigh 190 and i had to jump up and down like a mother fvcker to get the shock in
Old Aug 25, 2006
CenZ's Avatar
PWIT
didnt i do the jumping on your car?
Old Aug 25, 2006
RHCP0801's Avatar
oh yea thats right, i wasnt heavy enough for it lol....i was under the car hammering it in while you were jumping on it, damn i felt so safe under there
cmart1209
May 29, 2015 04:52 AM
vtec_concept
May 24, 2015 10:27 AM
edgenet
Apr 28, 2015 07:49 PM
Thees1
Apr 14, 2015 08:23 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
