noise after drop
Old Aug 13, 2006
tbaleno's Avatar
tbaleno is an unknown quantity at this point
noise after drop
Basicly when I start from a stop sign I roll a few inches and then I feel shaking for a 1/2 second to a few seconds. It happens at slow and fast accelerations. The sound is the worse under heavy acceleration and is quieter under lighter acceleration.
The stearing wheel doesn't realy tug to the side and I can barely feel it in stearing wheel.
I think it might be related to weight transfer but not sure.
I have Tein SS on a hybrid sedan with stock 185/75/14s for now.. Is there any particualar way I should adjust my softness or firmness? I don't have a front camber kit but the camber is right around 1.0. There isn't much of a gap (I plan on raising it up to a 1 1/2 to 2 finger gap. Will that help? Should the back or front be higher than the other to help with the weight distribution if it is a weight transfer problem?
Any ideas?
Old Aug 14, 2006
burke420's Avatar
The World Is Yours!
well from the sounds of it, you are either...
a.) getting a vibe from bent wheel
b.) out-of-balance wheel
c.) improper torqued wheel...btw..it's 80 ft./lbs
or you have some other loose components.
i like your car btw!
Old Aug 16, 2006
Ti71's Avatar
Ti71 is an unknown quantity at this point
Do you hear any sounds when you turn the steering wheel?
Old Aug 18, 2006
tbaleno's Avatar
Not that I noticed. And it goes away almost imediately as the car acceleratates.
Old Aug 18, 2006
mellow_civic's Avatar
mellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trusted
what kinda noise is it?
Old Aug 19, 2006
tbaleno's Avatar
A guy was in my car today and said it sounded to him like a clutch chattering. But I don't have a manual transmission. But thats what he said it sounded like.
Old Aug 19, 2006
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
Is it shaking or chatter?
Old Aug 19, 2006
tbaleno's Avatar
Sorry, I don't know the difference. I'm just reporting what this guy said he thought it sounded like.
Old Aug 19, 2006
CenZ's Avatar
PWIT
check your wheels man. mine was doing that and what happened is that my lugs backed them selfs off the studs. and the wheel was loose. lucky for me they cross threaded themselfs and got stuck.
15EXCoupe
Jul 30, 2015 12:59 PM
BootyDo
Jul 26, 2015 10:38 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
