Front camber bolt
Old May 21, 2006
legacyse's Avatar
legacyse is an unknown quantity at this point
Front camber bolt
Hello everyone.
I have Ingall's front camber bolt which Ingall says they can adjust up to 1+/- degree. I got a chance to use an alignment machine but the bolts only adjust 0.3 - 0.4 degrees ??
Is there any company out that make bolts which would give me actual 1 or 2 degrees +/- of adjustment? My ingalls clearly didn't do the job (the lobe are so small i figure they were useless before i install them.. but i did. oh well.)
I want to try SPC but i'm afraid they are just like the Ingalls.
Old May 24, 2006
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
i have the 16mm spc and on the box it says +/- 1.75 but i took it in to get an alignment and my front left without the camber bolts is 1.5 positive and right is .5 negative. the mechanic looked at the camber bolts and said that there is no way they are going to correct it 1.75, or even 1.5. He guessed they might adjust +/- 1 degree.
Makeice3498
Jul 2, 2015 11:13 AM
PierrePierre
Jun 17, 2015 06:22 PM
ayzan
17
Jun 30, 2002 12:36 PM
ernhole1
Dec 6, 2001 12:05 PM
ImmortalEX
Oct 31, 2001 10:00 PM
