camber plate vs camber bolts
Old Apr 19, 2006
CIVIC X3's Avatar
CIVIC X3 is on a distinguished road
ok...i;ve been searchin and i cant find any information on the camber plates. i know what i camber kit is, and what the front camber bolt look like..does anyone have a pic of the camber plate, or why is it better then the camber bolt. thnx in advance.
Old Apr 19, 2006
Hawaiian_Built's Avatar
...JDMDC5...one day...one day...
Hawaiian_Built is an unknown quantity at this point
can u tell me where the camber bolts go?
Old Apr 19, 2006
Touge Whore's Avatar
K-DUB
Touge Whore is an unknown quantity at this point
Camber Plates mount on top of the strut itself....this is the area under the hood that you mount strut bars too. Camber bolts insert where the knuckle attaches to the strut. You will see two bolts whenever you remove your tire. It is generally the top bolt that is exchanged for the camber bolt. Plates are much better in my opinion and have less chance of slipping over time.
Old Apr 19, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
http://www.7thgencivic.com/forums/sh...d.php?t=200089
Old Apr 19, 2006
CIVIC X3's Avatar
ok...i know about the camber bolts being loose after a couple of months that why i was asking about the camber plates...what brand out there is better then the camber bolts and does not cost an arm or leg...
Old Apr 19, 2006
K-DUB
You're going to have to search, it's your money, not mine.....Brand like Hotchkis, K-Mac, Tein, etc. etc. etc. are going to be quality.
Old Apr 19, 2006
CIVIC X3's Avatar
thnx for the brand...i just needed somewhere to start. because when i went on yahoo and type in honda camber plates/ civic camber plates, they be coming up with some useless a$$ website..
Old Apr 19, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
ground control Cheaper than the rest, but camber is adjusted from the bottom of the plate, K-mac expencive, but camber and CASTER adjustable, Hotchkis expencive but..... it's HOTCHKIS! as for Tein, they don fit on oem sized shocks unless modified as boiler has done
Old Apr 19, 2006
CIVIC X3's Avatar
they should fit with tein basic without modification then right? and is it called pillowball upper mount instead of camber plate. and also is the SPC rear camber better then ingall rear camber, vice versa...
Old Apr 20, 2006
K-DUB
What he said....I forgot about Ground Control.....
Old Apr 21, 2006
Jap-Euro Fusion
No, they don't fit the basics without mod. Tein is retarded.
The GC plates require use of GC hats (and the rest of the GC coil set) and I've never met anyone who found those to be easy to deal with.
Hotchkis is the only one I'm aware of that makes ones that work with stock springs, but I think they're discontinued.
You need to be doing some searching.... this has been gone through a couple times.... the consensus usually seems to be '**** it' unless you're hell bent on getting it to work.
Old Apr 21, 2006
CIVIC X3's Avatar
damn i heard that the camber plates is alot better so i was lookin into it. i guess i'll jus go with the bolts and go with the hassel havin to get it re tighten. thnx boilermaker and touge ***** for the info. and i DID really search. i;ve been on here for a while, and not lazy to search.
Old Apr 21, 2006
djmota's Avatar
Just get good quality camber bolts from spc. They use an all metal self locking nut that works pretty good. I have been running them for years with no slipping problems.
GolNat
Jan 12, 2021 09:06 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
