noob alert lol
noob alert lol
^ what he said but the pillow ball and the plate assist in adjusting the camber and ability to change the dampening factor
A pillowball is merely the spherical bearing.
The rest of the crap is extra stuff that it also has. You can have a stationary pillowball. The only thing the PB affords is a solid upper mount (i.e. no rubber isolator).
ok so a pillowball basically helps with the camber of the car and the dampening? and what is the top mount bearing if its not the same thing geez i feel like such a rookie im not used to being in this position lol
Originally Posted by slammedcivic85
ok so a pillowball basically helps with the camber of the car NOand the dampeningNO? and what is the top mount bearing YES if its not the same thing geez i feel like such a rookie im not used to being in this position lol
you need to do some searching and make that decision yourself. Its dependent on the way you intend to drive the car and how much stuff you feel you actually need.
ricer_em2
May 11, 2016 08:09 PM
AffliictiioN
Sep 16, 2015 02:21 PM
