Possible to use 2 different types of springs on same car?
Old Apr 17, 2006
daviddittmer's Avatar
daviddittmer is an unknown quantity at this point
I feel like my rear end is dropped the perfect amount... no gap, just a tiny tiny bit of tuck. The front, however is about 2 fingers. I am on neuspeed sport and Tokico HP. So, can I just get some springs with a lower drop, but only for the front? I can't think of any reason why this would cause a problem.
Old Apr 17, 2006
eye_see_you's Avatar
let the devil out
yes its very possible to do that such as running the tokico HP struts with eaibach proline springs in the back and sportlines in the front to eliminate the sage factor with a heavy system or something
Old Apr 17, 2006
BRCivic's Avatar
BRCivic is an unknown quantity at this point
yeah, i have different springs in the front and rear for the exact same reason
Old Apr 17, 2006
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
Yeah its possible. I have Tein H Tech's in the rear and Tein S Tech's in the front. My reason why is becuase of two things body kit and system. Haven't had any problem at all. I don't have pics now but soon.
Old Apr 17, 2006
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
is that what you're running? do you have any pics??? does anybody have pics of this setup?
Old Apr 17, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
He sold his Vic sometime ago. He has RSX now.
Look at his sig for the link to his Vic'. It looks very nice!
Old Apr 17, 2006
let the devil out
yes check my sig and look at my civic pics
you took the words out of my own mouth thanks man
Old Apr 17, 2006
oh thats your car!? Ive checked it out a few times, it does look nice.
on the last pic in the album it looks like the difference in height is pretty drastic? is there really a big difference or is it just the angle of the pic - seeing as the other pics don't look as drastic.
(by difference in ride height..i mean like a stock neon...ya know how its way higher in the back than it is in the front? also like some guys do to old school mustangs and muscle cars, having the nose way down and the back high up)
Old Apr 17, 2006
let the devil out
the picture does not do it justice but the downhill slope did not help there so check out two other pics of the setup
Old Apr 17, 2006
wow that looks sweet. thanks for posting those pics!
1 more question...how'd you get those springs? did you buy a whole set of prokits and then a whole set of sportlines? or can you get them separate somewhere?
oh...and are those tires 35 or 40s??
Old Apr 17, 2006
let the devil out
for the springs look around on e-bay I found them new and picked them up seperate for the rears
the tires were 35's
Old Apr 17, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
FYI, ground controls or coilovers are better suited to perfecting drops than mix-matching springs with different rates. Lowering spring kits are designed to work as a 4 piece unit, and swapping springs can make for a car that is unpredictable. But then again, if you are going for teh look and just cruising, it doesn't matter.
Old Apr 19, 2006
What would you guys recommend that I get to drop the fronts a little lower, somewhere between a half inch to an inch? Again, I am on neuspeed sport right now.
Old Apr 19, 2006
let the devil out
that is true but unless your doing auto X its not major of an impact with Tokicio Hp's I had a few different setups and I ended up with different springs due to the system in the trunk etc. The sway bars were upgraded and struts bars as well so my suspension was well rounded. For looks its not a matter its mainly for not having that sag in the rear that people do it .
mattdoc
Mar 14, 2017 12:10 PM
oneheadlight
Apr 29, 2015 11:30 PM
GaryFishell
Apr 24, 2015 06:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
