RSX control Arms fit?
Old Mar 22, 2006
RAZRBLD's Avatar
TEIN MAN
RAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura aboutRAZRBLD has a spectacular aura about
Will JDM INTEGRA TYPE R DC5 LOWER CONTROL ARMS fit the EM2?
Old Mar 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
not without work.
Old Mar 22, 2006
RAZRBLD's Avatar
TEIN MAN
damnit what work needs to be done?
Old Mar 23, 2006
Jap-Euro Fusion
They're shorter (brembo knuckles), the sway bar is for a K subframe swaybar, but mostly, they cut 30mm off the front track width of the car and play hell with the alignment settings.
Old Mar 23, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
The Hondawerx swap car has the JDM DC5 TypeR suspension (control arms and all). The track was actually wider than stock and it just didn't look right (I've seen it in person during the build and after). The rear tires actually got cut down from rubbing on the edge of the wheel well so much.
IMO, You're better off sticking with the stock EM2 LCAs.
Old Mar 23, 2006
TheSmuggler's Avatar
Damn shorter? I thought they were longer since the axels are wider on the type-r
Old Mar 23, 2006
Jap-Euro Fusion
A lot is built into the knuckle because of the brakes. The control arm if I remember correctly is shorter.
Its sufficient to say though, just leave them be unless you're doing the entire suspension with the knuckles and all. Stick to the EM2 ones.
Old Mar 23, 2006
Yep, shorter or longer your better off stock lol
GolNat
Suspension DIY
May 12, 2022 06:49 AM
GolNat
Sep 10, 2015 08:25 PM
bryden13
May 18, 2015 12:22 PM
Pudnite
May 9, 2015 07:51 PM
bluecoupe
Dec 20, 2001 07:12 PM
