best solution for separating tie rod
Old Mar 7, 2006
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
I'm lowering my car over springs break, and the only part of the job that scares me is separating the tie tod boot. I can walk to autozone, but not Honda, so I really need to get it right the first time. So, what's best? I have heard of people tearing the boot with a tie rod puller, but not air tools (but I don't have a compressor). Thanks guys.
Old Mar 7, 2006
mrDFWmechanic's Avatar
go to autozone you can rent the tie rod end puller rental tool its like 14.00 deposit, when you get done with it return it and get your money back. trust me i work there i know this
here's a link to what i'm talking about
http://www.toolking.com/ProductInfo.aspx?productid=2212
Old Mar 7, 2006
02silverbullet's Avatar
02silverbullet is an unknown quantity at this point
look on the diy...definitely dont use an air tool that will tear the sucker apart. i used a tie rod separator but split it because the one i used was sharp on the edges. so i ordered new tie rod ends to replace it just in case. it wasnt a terrible split but just wanted to be safe. either use a tie rod separator or a tie rod puller IMO. good luck
Old Mar 7, 2006
ragingSPAM's Avatar
I just burnt my tongue
get a tierod separator from autozone or kragen for like 10 bucks...thats where i got mine...its a hellofalot easier than using a hammer
Old Mar 7, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
I just hit the shock where the outer tie rod is and after like 5 blows i tapped underneith it and it came right out. I didnt need a seperator and Ive now used this same method to 3 7th gens trust me it works. right where the tie rod goes threw the shock hit it with a hammer.
Old Mar 7, 2006
Hayz's Avatar
thats what i did e-z and it works it's on Mex's DIY
Old Mar 7, 2006
legacyse's Avatar
legacyse is an unknown quantity at this point
My tie-rod did not came off as easy as many of you mentioned, I gave mine many hard wacks on the strut, sprayed lube yet its still stuck (maybe because of all the salt and crap from winter). I wiggle the strut and the tie rod, retry, and is still stunk on hard. The tie-rod separator was useless and it torn the boot slightly. I don't know what's wrong but it did finally came off forcefully with the screw/clamp type tie-rod separator or the so-called universal tie-rod end remover. It didn't fit right but it does the job.
Old Mar 7, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
i just used a HEAVY rubber mallet and beat on the nut till it broke loose. No problem for me.
Old Mar 8, 2006
R1Style's Avatar
I have done suspension installs on a 7thgen atleast 20 times without ripping that boot. First take off the tie rod nut and cotter pin, then all you have to do is get a hammer and start wacking the actual strut... right where the tie rod goes through... you can use a rubber mallet but I use a regular hammer. Hit it enough times and it'll loosen the tie rod and you can pull it out with having to rip anything or rent/buy any new tools.
btw... i would advise against hammering the actually tie rod bolt... if you hit it to hard to many times, you'll warp the threads.
Old Mar 8, 2006
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I use the screw type separator. It was about $10 at the local auto parts store. Make sure you get the one for compact cars since the standard one is too bit and dosen't fit.
Old Mar 8, 2006
c kim's Avatar
c kim is an unknown quantity at this point
I think Mex's DIY works the best. Spray some lube on the tie rod, and start whacking at it. Don't give it few whacks and give up. It takes around 20-30 good whacks. Use a regular hammer
Old Mar 8, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
^that worked perfectly for me twice already
Old Mar 8, 2006
HyaBoosta's Avatar
A brass punch and hammer work like a charm for me.My freind mushroomed his with just a hammer on his rsx and wow was it a bitch to rethread the tie rod.
Old Mar 8, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
I would put a small piece of wood in between the tie rod and the seperator. When I did mine the sperator poped of and messed up the threads. I had to get it retapped and now it works fine.
Old Mar 8, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Use this... but grind off the point from the end of the screw. It saves you the trouble of mashing the threads if you don't have it centered.
Old Mar 8, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
I use an airhammer. A couple hits on the bolt, and it pops right out.
Old Mar 8, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
sl0wEM2 has a spectacular aura aboutsl0wEM2 has a spectacular aura about
Stop being a little girl and HIT the strut HARD! and about 50 times!
Old Mar 9, 2006
acjones21's Avatar
I will probably use the item pictured because I really don't want to warp the threads from bashing it with a hammer and have to go to Honda for a new tie rod end. Thanks for all of the responses!
Old Mar 9, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
i just did this today with my install. just whack the **** out of it with a hammer till it is easy to pop out. just like the DIY. just keep whacking
Old Mar 9, 2006
sl0wEM2's Avatar
GO LOW or GO HOME
Don't hit the tie rod threads, hit the strut where it holds the tie rod.
Old Mar 9, 2006
tfnaaf's Avatar
BLDNPSI Mod
i do this sh*t 5 days a week all day long and have found it to be the best/fastest way.... BUT if your aim with a hammer sucks i suggest you buy a tie rod tool
Old Mar 10, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Mex's method worked like a charm
1. 3 second shot of WD-40
2. 5 hard hits with a metal hammer
3. Slight tap up on the tie rod bolt and it popped up like a mexican jumping bean
Old Mar 21, 2006
bluestreak's Avatar
^yup, done it about ten times already, that's exactly what happens, sometimes 10 hits with the hammer if it was a long night ..... lol
Old Mar 21, 2006
cj2185's Avatar
cj2185 is an unknown quantity at this point
DO NOT HAMMER! u will damage the tie rod end and will cost u more in the long run believe me. I damaged mine and had to replace the tie rod. It was 2 hard to replace. Had to take it to autozone cost me $230.00.
Old Mar 21, 2006
MajinB's Avatar
yea my tie rod was not damaged. it was whacked like 100 times. they are both fine. not even marks on assembley
Old Mar 21, 2006
cubanmike26's Avatar
If you would remove and re-install the whole suspension on your own for the first time, how long would this take approximately?
Old Mar 21, 2006
tfnaaf's Avatar
BLDNPSI Mod
frt suspension 1 hr
rear suspension 45 minutes
Tools and exp will varry
Old Mar 21, 2006
Thanks tfnaaf, though I think it may take me quite longer than that..
Old Mar 21, 2006
MajinB's Avatar
yea mine took 2 hours. longest part was gettin the tie rod to bang out.
rears took like 4 hours lol. control arm, and hex nut probs, it sucked.
Old Mar 21, 2006
The front was prolly about 30 min/side, This was the first time I'd ever taken off struts so I was tip-toeing
It took 4 hours for the rear due to the fact the lower strut bolts were BITCHES And I broke TWO ratches to get them loose. I had to put a jack underneath them and jack them up to get enough leverage to get them loose
Dude, You did something wrong. you probably hit on the TOP of the actual tie rod, NOT where it mounts on the strut housing. There's no way you could damage the tie rod if all you hit is the mounting point, not the actual tie rod. Unless you had a sledgehammer....
