car sitting too high =/
Old Mar 5, 2006
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
got 1.5" drop, less dan a finger gap in the front, and 1 finger gap in the rear. but my car is still sitting too high off the ground. i got oem lip kit, and 215/45/17. will bodykits sit lower off the ground?
Old Mar 5, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
dude its useless without pics
Old Mar 5, 2006
ohioex's Avatar
ohioex is an unknown quantity at this point
^^^ agreed. You could run a set of coilovers and get 205/40/17 tires
Old Mar 5, 2006
CustomXSpunjah's Avatar
CustomXSpunjah is an unknown quantity at this point
imho 1.5" drop is perfect although its one finger length, it still looks good. your tires might be a little big though 40's would be nice.
Old Mar 5, 2006
MajinB's Avatar
eh, it could be anything. we need pics. tire size don't say nothin. what kind of rims? what kind of springs? where are the pics?????
Old Mar 5, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
of course, you're riding on 215/45/17 which puts your civic at 2" or higher from the hub to ground.
you can have 1.5" drop springs on a civic with 225/30/19 and it'll still sit higher than factory specs.
a ricekit will only make the car "look" lower since its closer to the ground. the kit/lip will fill in that empty gap to make it look like its sitting lower
Old Mar 5, 2006
still strange though. A guy down the road has a civic dropped 1.5"f 1.3"r and 215/45/17 and it looks perfect to me. Totally stock body also
Old Mar 5, 2006
MajinB's Avatar
like i said, what kind of wheels? and a "ricekit" is not a rice kit at atll. body kits are for show. respect them. and it IS lower to the ground, cause the kit is part of the car. yes, the appearance is there cause the kit is there for the lowered aspect too
Old Mar 6, 2006
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
215/45R17 size tires have a radius only .19" (1/5") higher than stock*, so the overall diameter changes by only by 2/5". The difference in size is negligible when it comes to ride height; only 1/5"
* assuming 185/70R14. If stock is 185/65R15, then the radius difference is only 0.08", which is about 1/12" !!!
Old Mar 6, 2006
MajinB's Avatar
dude you get rep^
Old Mar 6, 2006
jdm_veloz's Avatar
1st of all, 45 and 40z is not a bigger difference in height, 2nd the pics are shown in my gallery, 3rd i have a lip kit, n still looks too high off the ground. but i cuz i m gonna go with super street or flex, n drop 2" off those. rite now i m riding on s techs.
Old Mar 6, 2006
MajinB's Avatar
ok i just saw your pics. they are at night. it looks dropped with almost no gap. day pics might be better. the tire looks thick as ****. that might be your problem. thinner tire man
Old Mar 6, 2006
imho the s-tech is the best drop for the 7th a 2" is wayy too low you'll scrap everything and say goodbye to your exhaust on the first speed bump you encounter. And btw there is a noticeable difference between 40's and 45's
Old Mar 6, 2006
ironchef's Avatar
Sometimes the shape of the tire makes the sidewall look bigger; some tire brands make their shoulders more square or rounded. The rideheight difference (between 40 and 45-series) might be small, but you're right, the visual difference when it comes to sidewall height will be noticeable.
Old Mar 6, 2006
D5cIvIc's Avatar
i'm dropped 2.5 with 215/40/18 and its perfectly flushed.
Old Mar 6, 2006
2.5" on 18's with 40's.....are u talking about the racing harts or the seven mods? the RH's look like they are rubbing when u turn....
Old Mar 6, 2006
ironchef's Avatar
Now, why would anyone give me negative rep for anything I've posted in this particular thread?
Everything I've posted is either cold, hard calculations, or fact.
Old Mar 6, 2006
MajinB's Avatar
well i positive repped ya so it should cancel out lol
Old Mar 6, 2006
D5cIvIc's Avatar
talking about the seven mods. When i had the 17 on 40s on the racing harts i was dropped lower. Almost 3". They never rubbed, but on the seven mods i had to roll my fenders because they were rubbing in the back
Old Mar 6, 2006
ironchef's Avatar
Yeah, that makes up for it, appreciate it.
Old Mar 10, 2006
but your car was raised when you swithed to the seven mods i assume...
Old Mar 14, 2006
Nitto's Avatar
gone
Nitto will become famous soon enough
oem kits are never sitting on the ground.
roverben
Jan 21, 2019 05:16 PM
mikemc422
Aug 9, 2018 05:41 PM
usajags84
15
Aug 19, 2015 03:12 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
gabrown2
Apr 11, 2015 08:22 PM
