yes/ no? reguarding coil overs
Old Mar 5, 2006
4_door_fury's Avatar
4_door_fury is an unknown quantity at this point
got megan full coil overs..
is their anything i should do besides greasing up ends and pillow ***** b4 installation, is it safe to spray say WD-40 on the threads/ perch and/ or springs to prevent them from rusting or seizing .? lmk asap plzz! thanks
Old Mar 6, 2006
TeLLy's Avatar
Yes, it's an Acura EL
If you want to protect the threads, I don't suggest WD-40. In fact all WD-40 is good for is unsticking the odd nut or bolt, it's not a part of regular maintenance or car care IMO. Use something thick like axle grease or maybe anti-seize compound. Look up the DIY in here, I forget which of the suspension gurus wrote it (boilermaker? was it you?) but it should give you a better idea of how to protect your suspension. Myself I just used a wack of grease on the threads and will wash them off this spring. If you clean off the coilovers diligently and regularly enough youy won't have to worry about seizing.
aZnVoYCe
Jan 4, 2002 12:21 AM
CIVICINJEN
Dec 19, 2001 04:47 PM
duyaknow
Nov 23, 2001 07:28 PM
CIVICINJEN
Nov 16, 2001 11:44 AM
CIVICINJEN
Nov 16, 2001 09:42 AM
