Wheel Alignment help!
Old Feb 22, 2006
HyaBoosta's Avatar
Well I have access to a alignment machine. I also have camber kits for the front and rear.(Ingalls in front) I was adjusting my camber and toe last night and was loosening the bolts on the strut and pulling the wheel outwards while having the bolts tightened. Is there a better and easier way to adjust the camber thats more precise? Also whats the easiest way to adjust the toe. thanks Pics would be even bigger help.
Old Feb 22, 2006
C25A1guy's Avatar
C25A1guy is an unknown quantity at this point
On the front, the easiest way to adjust camber (well, maybe not exactly much easier, but more accurate) is to utlize camber plates. As far as toe, all you do is take a wrench to the tie rod and turn it until you're in the green. It'll be a tight fit for hand, arm and wrench, so, best advice is to be paitent.
Old Feb 22, 2006
Rennen's Avatar
New Mod on the Block
hey since you're in miami, can you hook me up with a alignment ?
Old Feb 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
http://www.7thgencivic.com/forums/sh...d.php?t=205775
Old Feb 22, 2006
C25A1guy's Avatar
Well, he has access to an alignment rack, so I doubt he's gonna need to do the alignment "trackside style"
Old Feb 22, 2006
HyaBoosta's Avatar
yeah I have ingall camber bolts on the tokico's from what I heard, all I need to do is tighten the bolt to adjst the camber or loosen it. Is this the easier way?
Old Feb 22, 2006
HyaBoosta's Avatar
If I can get this down on my car I wouldn't mind the practice
Old Feb 23, 2006
tfnaaf's Avatar
BLDNPSI Mod
Not following ya.... The front camber bolts work by losening the second bolt and camber bolt and turning the camber bolt until you get the camber reading that you desire. As for the toe...... Start car ..Center wheel... depending on aligner, basically center wheel and adjust right and left toe untill toe comes in to spec with steeering wheel centerd. Then start car and re-center wheel to ensure toe is still right on. hope that helps
Old Feb 24, 2006
Jap-Euro Fusion
Doesn't matter if he does it on a rack or not, the tie rods and camber adjustments still get done the same way, only the gauge is different
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
BryanM.
Aug 29, 2015 03:26 PM
jedi
Aug 3, 2015 04:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
