How Low Is To Low....
Old Feb 13, 2006
goodtimes's Avatar
i just got a set of megan coilovers and when i set the ride hight i sent very low(just about tuckin 16's) and i when to get an alingment done and he said they couldem adjust the toe any more b/c it was out of threads. so my Q is to you what other things can mess you if you go to low.
and what do you guys think is the minmin ride i can go with out messin and suspension part up.
Old Feb 13, 2006
Nick's Avatar
Formerly 2blu
I thought that camber, not toe is affected by lowering.
Old Feb 13, 2006
Zzyzx's Avatar
Autocross Junky
any time you change camber angles you also change toe angles... and toe will eat tires 10X faster then just about any amount of negitive camber.... BUT since its alot harder to see toe angles, most people just blame camber when their tires wear out quickly.
Other Handling problems of going to low...
1. Bottoming out the suspension (specifically the front) mid turn = Understeer city.
2. too low of a ride height = loss of negitive camber under suspension compression = more understeer
Old Feb 13, 2006
Nick's Avatar
Formerly 2blu
I knew that, but i thought that u could always put toe back to 0 even after lowering. Where as u need a camber kit to get closer to stock.
Old Feb 13, 2006
goodtimes's Avatar
Zzyzx did you see my alingment specs on the other thread. what do you think would be a good ride hight for not messin anything up 1-2 finger gap
btw im on 16's
Old Feb 13, 2006
Zzyzx's Avatar
Autocross Junky
btw im on 16's
Finger gaps dont tell you any thing (Nither do wheel sizes)... given that what size tire you run greatly influences that measurement. what you need to look at would be chassis ride height.
but any way, from talking with the RSX guys it appears that a -1 to -1.5 would be around optimum drop, as it gives you plenty of suspension travle and doesnt dip you in to the relm of adding positive camber on the nose as the suspension compresses. but then this also depends on spring rates, as softer spring rates will require less of a drop in order to maintain suspension geometry.
Old Feb 13, 2006
acidbaby's Avatar
The Beez Kneez
+1rep man^^^ as ussual lol.
Old Feb 13, 2006
goodtimes's Avatar
Well i have the megan coilovers and i think there right around 8k front 10k rear so does that mean i would half to go lower b/c i have a higher spring rate, im runin 205/50/16 now. May i ask how you determinde your drop.
and how do you get it the right hight. Like when i adjust my coils to lower it or rase it i just determind it by lookin at it. is that what you do or do you do it some other way.
im looking for a sporty kinda drop but allso will put out the best handeling too.
Old Feb 13, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
too low is when people are focusing on your car when your about to go over a speed bump, just to watch to see if you scrape the **** out of any part of your car. other than that, if you have the right setup its never too low.
Old Feb 13, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Top of the wheel arch to the center of the hub. OR top of the fender to the ground.
Thats the easiest way to find chassis height.
Old Feb 14, 2006
goodtimes's Avatar
^^^ yeah thats probley going to be my best bet to do.
my fronts are at about 23inch of ground to fender and the back is about 24inch.
whats your guys (boilermaker,Zzyzx) if you know so i can compare with you guys.
maybe i rase it to 24inch in the front and 24 1/2 in the rear that should be good right
Old Feb 14, 2006
LowLife's Avatar
LowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to allLowLife is a name known to all
You can NEVER go too low...
Old Feb 14, 2006
Jap-Euro Fusion
12 7/8" from the fender arch to the hub center.
Old Feb 14, 2006
goodtimes's Avatar
well mines about 12" form the fender arch to the hub center.
so im going to rase it up some.
Old Feb 14, 2006
goodtimes's Avatar
Old Feb 27, 2006
sdt532000's Avatar
sdt532000 is an unknown quantity at this point
Question about dropping
I am getting 205/45/17 but I don't wanna dropped.What do u think about driving city especially potholes and speedbumps?
What's the main advantage or disadvantage getting dropped ?
thanx
CraigW
Aug 18, 2015 07:06 AM
jwalkerck1
Aug 17, 2015 10:03 PM
JetsterDajet
Aug 16, 2015 01:56 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
alxz310
Jul 30, 2015 12:18 PM
