problem getting rear to lower all the way
Old Feb 5, 2006
02blkhonda's Avatar
02blkhonda is an unknown quantity at this point
so i just upgraded from skunk2 springs and busted factory struts..I got gc's and yellow konis....anyways when i try to put the rear all the way down the adjuster keeps hitting the gold peice(the cup which the springs sits down in) can i cut that piece b/c it just barely scraps it or will that affect the way the struts performs..
Old Feb 5, 2006
saugashan's Avatar
This is not my batman glass!!
saugashan should not be trustedsaugashan should not be trustedsaugashan should not be trusted
hows the ride on gcs and konis
Old Feb 5, 2006
02blkhonda's Avatar
GREAT!!!! by far the best investment so far and i havent even got it lined up...also does anybody else have problems adjusting the rear struts while they are installed...i had to jack the car up and loosten the top bolts so the adjuster would fit in that tiny *** hole where the top of the strut is. is there a better way to do this?
Old Feb 6, 2006
burke420's Avatar
The World Is Yours!
well i dont got the GC's or Yellow's but my AGX's and Skunk2s coilovers didnt affect with a lil trimming on the spring perch. i didnt affect anything on my car, an ive been rollin with them since september
Old Feb 6, 2006
02blkhonda's Avatar
so you did trim a little off the spring perch? did you also have to do that to lower it all the way?
Old Feb 9, 2006
02blkhonda's Avatar
also does anybody have problems adjusting rear struts while they are installed....i have to loosten the upper bolts and jack the car up so the damn tool will fit in there to adjust the stiffness...is there a easier way to do this????
rtachs
Jul 16, 2015 05:32 PM
vtec_concept
May 24, 2015 10:27 AM
Pudnite
May 9, 2015 07:51 PM
shindrome
Exterior
May 5, 2015 02:50 PM
