which to pick?
Old Feb 5, 2006
allmotor's Avatar
nor cal 7thgens
which to pick?
i like the neuspeed race springs but want to go lower. I searched and came up wanting either ground control coilovers or save and later get omni power coilover. Which one do most people on here like regardless of price? I just want to slam it without having to go bags etc.
Old Feb 5, 2006
Mike04Civic's Avatar
Mike04Civic is an unknown quantity at this point
correct me if I'm wrong, but arent the ground control coil-overs, made for the 7th Gen civics, supposed to be designed to work with our stock shocks?
Eliminating the process of buying after market shocks.....that would be a big factor to me...
Old Feb 5, 2006
CenZ's Avatar
PWIT
doubtful our shocks sucks
Old Feb 5, 2006
and yet.....
http://www.truehonda.com/inventory.p...ctdetail&id=22
"Ground Control Coilover Kit for Honda Civic 2001
Height Reduction Range - 0"-2.5", Include bump stops.
Note: This Kit will only fit Stock, Sachs, Boge Shocks.
Ground Control Adjustable Coilover Kits allows you the option to customize the ride height of your vehicle. Unlike other spring kits that require removal of the strut assembly, the unique design of the Ground Control kit allows for quick, easy adjustment. Simply lift the corner(s) to be adjusted and spin the adjuster up or down to raise or lower the vehicle. Ground Control spring kits are designed to be used with either stock or aftermarket shocks.
All height adjustable kits feature Eibach Springs. These high quality springs offer a lifetime warranty against defects. All adjusters consist of a threaded sleeve and adjustable spring seat and are made using 6061 aluminum, anodized for greater durability and appearance. All other adapter hardware is machined from the same high strength 6061 T-6 aluminum.
Note: This Kit will only fit Stock, Sachs, Boge Shocks. Tech note: For the Front, trimming of stock spring seat allows added range of adjustment"
Old Feb 5, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Just because it fits them doesn't mean its smart to do it.
Its the stupidest thing you could do.
Using GCs without a set of KONIS is not a smart idea.
Old Feb 6, 2006
allmotor's Avatar
nor cal 7thgens
i know they arent true coilovers that need shocks i nvr said they were and that wasnt even the question. I said what would people pick. My shocks r fine already checked them. Now does anybody on here have omni or ground control and like the way they ride?
Old Feb 8, 2006
ragingSPAM's Avatar
I just burnt my tongue
here is gc's website
http://www.ground-control-store.com/
u can order any combo for stock, aftermarket shocks, koni inserts etc...and u can pick spring size/rate and sleeves
Old Feb 9, 2006
allmotor's Avatar
nor cal 7thgens
thanks i already knew that....... i want to know who likes what better.
ken4444
Sep 30, 2015 07:37 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
Luluharp
Sep 27, 2015 11:56 AM
meicalnissyen
Sep 25, 2015 12:12 AM
Skunkone
Sep 24, 2015 04:38 PM
