For those with aftermarket Front camber bolts!
Old Feb 8, 2006
sternfan's Avatar
Whack Pack Member
sternfan is an unknown quantity at this point
Question For those with aftermarket Front camber bolts!
I was wondering how your front camber kit (SPC, Ingalls, ETC) are holding up after installing them. Have they slipped on your causing your alignment to be off?
thanks
Old Feb 8, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
They all slip, its the nature of the beast, and the reason I hate them so much.
Old Feb 8, 2006
c kim's Avatar
c kim is an unknown quantity at this point
Yeah, mine are slightly off spec. everytime I check em. But we gotta live with it even though they suck. Unless you're willing to shell out some serious dough for some full coilovers with camber plates.
Old Feb 8, 2006
straightfaced's Avatar
straightfaced is an unknown quantity at this point
Ive never had problems with them
Old Feb 8, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
is the slippage noticable daily??? or is it like every couple month(s)???
Old Feb 8, 2006
Jap-Euro Fusion
If you measure in .0001 of a degree or something, then yeah, you may see it daily, but its cumulative over a period of time. Depends how hard you drive the car and how many potholes you hit.
Old Feb 8, 2006
i get mine aligned every year and the second time they said there was nothing off spec (all green). and i drive aggressively around the corners sometimes and the roads here are like going over speedbumps all day.
Old Feb 8, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
I have had mine into the shop 3 times over the last 3 years just for a check up and i have been in the green all 3 times. Spc is an excellent product.
Old Feb 8, 2006
ya i think if you don't autocross it should last for a while. i'm in the shop every few months for a balance cause the stupid weights keep falling off from the bumpy roads.
Old Feb 8, 2006
tfnaaf's Avatar
BLDNPSI Mod
Had mine a few years now and never had an issue, but then i drive like an old man.... wait I am an old man !
Old Feb 9, 2006
streetglower's Avatar
have had mine on for over a year or 2 and have never had any problems. I usually get the car aligned ever 3-6 months since it is free and each time the numbers are always within specs.
Old Feb 9, 2006
Zzyzx's Avatar
Autocross Junky
I have mine completely bottomed out... so theres really no where for them to slip to. (around -2.6 Deg camber)
Old Feb 9, 2006
sternfan's Avatar
Whack Pack Member
Thanks for the replies. SPC recomends 80lb/ft to torque down the bolts, are you guys using higher numbers?
Old Feb 9, 2006
Hank_Si's Avatar
Hank_Si is an unknown quantity at this point
This is my first post I dont know if I should start a new topic or just use this one. I have EP3, recently got it. I lowered it and have camber kit with these bolts that are under discussion(no problems yet). Only question I have is with the specs for alignment. Should person doing the alignment use factory specs or are there different ones for being lowered? I have Skunk2 springs on it which dropped it about 2 inches and I cannot find any specs for the alignment for them. Thanks.
Old Feb 9, 2006
WEAPON-R CIVIC's Avatar
WEAPON-R CIVIC will become famous soon enough
had spc for four years now with no problems
Old Feb 9, 2006
tfnaaf's Avatar
BLDNPSI Mod
For the most part stock specs are what i always suggesting to start with on any modified car. Then re-evaluate the tire wear after say 1000 miles to see if it will require more or less toe/camber and go from there. Unless your setting it up for racing then im sure some of our racers will suggest some ideal /prefered specs.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
LionSpratt
Jan 29, 2017 11:07 PM
ernhole1
Dec 6, 2001 12:05 PM
ImmortalEX
Oct 31, 2001 10:00 PM
