Koni install problems?
Old Feb 1, 2006
5.0calypso93lx's Avatar
5.0calypso93lx is an unknown quantity at this point
I just got a set of koni struts/shocks for my g/f's 01 civic ex. I bought the 50mm from a guy on here. I've looked through the diy on here and it looks like it will be a really easy job, but then when i look at the front struts, they do not have the spring perch assembly on the bottom of the strut like in this pic:
My question is, is the strut part of the spring perch assembly, or do i just take the strut out of the assembly and replace it with the koni strut? I've already done a search on this and haven't found anything.
Old Feb 1, 2006
Old Feb 1, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
This is exactly what happens when you don't do your research ahead of time.
Konis are inserts. You have to gut the stock struts, then the Konis bolt into the housings.
Its detailed here
http://www.7thgencivic.com/forums/sh...d.php?t=155272
Old Feb 1, 2006
Hey thanks a lot man, you can go ahead and close.
Rogelio Rey
May 24, 2015 08:30 PM
Youshoe
May 22, 2015 09:36 PM
cukaracha
May 16, 2015 07:36 PM
Flatlander
Nov 16, 2001 05:38 PM
