TEIN SS question... this sucks!
Old Jan 3, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
Hey... Ive had my TEIN SS's installed for a while, and lately been wanting to drop the car a little more, believe it or not... the fronts are at the lowest height setting! (its weird because the rear ones could go probably an inch lower if I really wanted to, but it would be so uneven). Is there anything I can do to make it lower, besides the obvious (changing suspension) Which might be an option for me down the road if there is no other way.
The pictures here show the height of the front and the space from the wheels to the fender... (that is at its lowest height setting)
if there is something I can do please let me know
I guess what im trying to say , or what im hoping for is maybe There is something in the front suspension I can take off (that I was supposed to take off) that will give me a lower drop or something?
Old Jan 3, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
I've got Tein S Tech's and I'm on 17's with TOYO Proxes4 215/40/17 and my front is a little bit lower than that...
Old Jan 3, 2006
could it be because 16" is too small for em2?! lol
Old Jan 3, 2006
I think if you have smaller rims the car would drop more...I dont think that's your problem.
Old Jan 3, 2006
yes the car would drop more but you would still have a gap in the fender.. which i guess is my main concern... It supposidly drops 0-3"
Old Jan 3, 2006
Install them again to see if that was the problem.
Old Jan 3, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
how many inch drop is that already?
Old Jan 3, 2006
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
nice volks.......
Old Jan 3, 2006
i dont know how many inches its dropped I never really measured... I know its definately not 3 inches!
Old Jan 3, 2006
civic01vtec's Avatar
hmmm........i still have 4 threads to go on the front and i have a 1/2 finger gap with 17's. On my 15' steelies with winter tires, i am tucking.
Old Jan 3, 2006
hustlelikem0fo's Avatar
yea, when i had my steelies on for the winter with my TeinSS the front had no gap at all..... this is weird.
Old Jan 3, 2006
Axxe's Avatar
Axxe is an unknown quantity at this point
You might have installed a ring in the wrong spot. However, maybe the guys that go lower have the pillowball upper mounts or camber plates.
What year is your car? If it's got the early style stock strut mount (no ball bearings), then you need to use the gold ring, if you have the new style (with ball bearing sleeve) you need to use the green ring.
Old Jan 3, 2006
goodtimes's Avatar
^^^so your sayin that if he got the pillowball upper mounts the teins would be lower than it is right know.
Old Jan 3, 2006
J Smith's Avatar
J Smith is an unknown quantity at this point
nice wheels
Old Jan 3, 2006
thanks for the compliments about the wheels I think they would look better with a 1 finger gap!
My car is a 2002 Civic Ex, When I installed the coil overs (front ) I didnt change anything (as in upper mounts) it went right in, I was hearing mixed answer about needing an uppermount from an 01 etc.
And I have the Tein SS's w/o the pillow ball mounts
The car rides fine... No noises, squeaking or anything, its just I want it lower!
Old Jan 3, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
damn your right. it looks almost stock...do a re-install.
Old Jan 3, 2006
I will try and get to that either today or tomorrow....
Like I said earlier I have an 02 civic... I didnt not change any uppermounts to an 01 (like I heard from a few people you have to do)
can that be part of the problem?
everything rides good, no noises or anything exept for the problem of not being able to lower it more
Old Jan 3, 2006
bump!
Old Jan 3, 2006
Originally Posted by ruffryde009
bump!
Old Jan 3, 2006
Zzyzx's Avatar
Autocross Junky
Looks good to me, Nice sporty drop, and not too low as to compromise the geometry of the suspension. Why hinder the cars handling in pursuit of a "look"?
Old Jan 3, 2006
true... I agree BUT... I still think I have to fix it because Its set all the way down (I heard it can cause damage to the struts eventually if left long)
Old Jan 3, 2006
Axxe's Avatar
Hmm. MrXclusive car is the same height as yours but his are 2/3 up.
Tein SS w/o pillow ball mounts
2001 LX coupe.
Try to pull it apart and verify the tein diagram to make sure you didn't stick both rings in their, or something silly like that.
Old Jan 3, 2006
WILco! im gonna take a rim off and take a picture of it right now see what the hell is going on under there
Old Jan 3, 2006
hey I took some pics!!! hopefully this helps you guys help me out :-D
according to the diagram everything looks good!
Old Jan 3, 2006
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Looks like you have two of the gold rings up there instead of one, however I'm not a pro so I'll leave it to Axxe to decide what's wrong. He knows his ****
Old Jan 3, 2006
thats what I thought but on the diagram it looks like it that 2 layer I have also
Old Jan 3, 2006
bump...
Old Jan 3, 2006
any suggestions anyone?
just went out for a little night driving... ahh so funnn
Old Jan 4, 2006
Axxe's Avatar
Holy ****. No wonder you can't lower it anymore. It appears to me that you have your factory upper spring perch sandwhiched between the ring and the upper strut mount.
Outlined in Red is the factory upper spring perch, it needs to go.
Outlined in Blue is the upper strut mount, it stays (mandatory)
Outlined in Green is the adapter ring. It is made for the early model uper strut mounts. Check the Tein diagram when you remove your upper strut mount to verify the type of upper mount you have. Gold is for early, green is for late.
Good luck, post pics of the upper mounts if you are not sure which ring to use.
Did you not experience some noise? I'd imagine it'd be pretty loud.
Old Jan 4, 2006
wow thanks for the reply!
I will try and see if I can fix this as soon as possible
and no.. no noise at all and a very good ride... close to stock but with much better handling
