TEIN SS question... this sucks!
Old Jan 4, 2006
  #31
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
o yea I forgot to say I guess I didnt look to much into DETAIL when installing because when I bought them (used) thats how they came...
Old Jan 4, 2006
  #32
Axxe's Avatar
Axxe is an unknown quantity at this point
No problem. Just make sure you put some white lithium grease all over the collar and adjustment bolts, so they don't seize up on you.
Old Jan 4, 2006
  #33
goodtimes's Avatar
o man, be shure to post your pics with the new drop lol
Old Jan 4, 2006
  #34
Axxe's Avatar
Yeah, pics of RE-DROP
Old Jan 4, 2006
  #35
yes definately new pics of redrop... i have a few new extra things for the car for next photoshoot too :-p
Axxe is a Genius! You made my day mane
Old Jan 4, 2006
  #36
about the lithium grease can that be bought at advanced auto parts?
Old Jan 4, 2006
  #37
goodtimes's Avatar
^^^ yeah any auto parts store have it?
Old Jan 4, 2006
  #38
alright well im about to go find out... Im going to advanced auto parts!
Old Jan 4, 2006
  #39
Axxe's Avatar
Yeah, any good auto parts store should carry it. Get the biggest tube available, it comes in handy.
Old Jan 4, 2006
  #40
YUP! Bought a tube about 1 foot long... Thanks... looks like Im going to have to hold on the REinstall till saturday
Old Jan 5, 2006
  #41
goodtimes's Avatar
ok keep us posted
Old Jan 5, 2006
  #42
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
post pics of it fully slammed!
Old Jan 8, 2006
  #43
Originally Posted by Axxe
Holy ****. No wonder you can't lower it anymore. It appears to me that you have your factory upper spring perch sandwhiched between the ring and the upper strut mount.
Outlined in Red is the factory upper spring perch, it needs to go.
Outlined in Blue is the upper strut mount, it stays (mandatory)
Outlined in Green is the adapter ring. It is made for the early model uper strut mounts. Check the Tein diagram when you remove your upper strut mount to verify the type of upper mount you have. Gold is for early, green is for late.
Good luck, post pics of the upper mounts if you are not sure which ring to use.
Did you not experience some noise? I'd imagine it'd be pretty loud.
Alright well did the reinstall.. On the red highlighted area there are 2 pieces... the one on the top (which is a light gold color) and the one below it which is a darker color gold (this can be seen in the picture)
The light gold color (the piece on top) thats highlighted red.. is one piece with the blue upper strut mount
So the only thing That I would be able to take off is the darker color gold piece under the light gold piece (highlighted in red by Axxe)...
I still the the upper strut mount from the 02... What do I have to do .. change to an 01? or what... im about to give up and throw these coilovers in the garbage... just kidding! butt its annoying me
any suggestions anyone?
Old Jan 8, 2006
  #44
Axxe's Avatar
Can you take some better pictures? It's a bit tough to see. I'm thinking you may need to use the "green" rings that came with the kit, if you have them that is.
Old Jan 8, 2006
  #45
ill try and take b etter pictures.... I thought it was either you have the gold rings (for my car, early years) or the green rings
Old Jan 8, 2006
  #46
centurioncivic's Avatar
centurioncivic is an unknown quantity at this point
iv yet to see anyone with 17s or below with no wheel gap on the ss. thats why im goin with progress
Old Jan 8, 2006
  #47
4 inches? dayum... I light the drop on mine now.. its just not photgenic with this drop though! (low angle shots look like crap)
and I dont know.. i might just end up buying tein pillow mounts see if that solves the problem (thats if i can get them seperately that is)
Old Jan 8, 2006
  #48
MrXclusivE's Avatar
yes you can get them separately but they'r not cheap!
Old Jan 8, 2006
  #49
damn... ive been searching right now and still can find it... whats the website where you can order the OEM mount and bearings ... and it will show you the diagram/picture of the suspesion assembly?
well till then ill just keep looking
thanks
Old Jan 8, 2006
  #50
well I came to a conclusion...
I am going to buy 01 mount and bearings for my car...
the mount and bearing on my car looks like the one on the right (with the extra lip hanging from the mount)
And I have the gold rings
So maybe thats the problem.
The coilovers go in just fine and make no noise at all with the mount and bearing I have now (which looks like the ones on the right, if you look at the pictures i posted)... just cant get a low not even semi- low drop
Old Jan 9, 2006
  #51
http://www.hondaautomotiveparts.com
is the website for parts with diagrams/pictures
Old Jan 9, 2006
  #52
Axxe's Avatar
Yeah, you definately need the green rings. Call Tein to see if they can send you the green rings to replace the gold ones.
Old Jan 9, 2006
  #53
TheSmuggler's Avatar
Werid, my friend with an 02 got the gold upper mounts and his worktwith no problem.... lol
Old Jan 9, 2006
  #54
mine work with no problem.. but it seems like the car is only dropped 2 inches...
so the solution would be what axxe said either get the green rings... or buy the 01 upper mount and bearing... which Is what I will be doing because they are on order already... ill keep you guys updated let you know if this fixes it...
Old Jan 11, 2006
  #55
bhoy's Avatar
bhoy is an unknown quantity at this point
i got 16" 205/40/16 toyo tires but i got my car way lower....
Old Jan 11, 2006
  #56
drew22mader's Avatar
There is gl@ss in my @SS...
bhoy, he needs help with his Teins, not you telling him your car is way lower, you don't have Teins so why buty in? Makes me mad when people do this sorry not trying to be mean.
But for your question, i have an 02 also with upperpillow ball mounts and i have at least 8 more threads to go down, i can tuck the fronts and dump the backs. Just doesn't make sense that you can't do the same.
Old Jan 11, 2006
  #57
[QUOTE=
But for your question, i have an 02 also with upperpillow ball mounts and i have at least 8 more threads to go down, i can tuck the fronts and dump the backs. Just doesn't make sense that you can't do the same.[/QUOTE]
Thanks for the response... what kind of upperpillow ball mounts are you using? the TEIN ones? Well the 01 upper mounts and bearings should be comming in later this week... and ANOTHER reinstall saturday....
ill keep you guys updated!
Old Jan 11, 2006
  #58
Yea i have the 01 upper mounts and bearings. I'm gonna slam mine with the new shoes come in, i'm gonna tuck a little bit of tire, there is no reason why you shouldn't, this is weird they are giving you this much trouble. keep us updated.
Old Jan 14, 2006
  #59
goodtimes's Avatar
any up date on theses?
Old Jan 14, 2006
  #60
nope! my Honda dealer still doesnt have the front top mounts and bearings (01)
Will update as soon as I get a chance!
GolNat
Nov 27, 2018 03:32 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
