rear sway bar LX
Old Jan 1, 2006
suthrninca's Avatar
suthrninca is an unknown quantity at this point
rear sway bar LX
Anyone think this would work for lx owners looking to bolt on a rear sway bar? I have seen the diy for the lx without using the progress mount kit and these tabs look similar to the ones that were custom made for the diy.
http://www.competitionengineering.co...?CatCode=10146
Old Jan 2, 2006
suthrninca's Avatar
anyone......
Old Jan 4, 2006
suthrninca's Avatar
thanks guys
Old Jan 4, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
it may work...u may wanna pm that person or measure up your own controll arm and also make sure the hole is the right size. i think most people would just go w/ the progress cuz its bolt-on.
it shows the dimensions on the site so u may be able to mock up a cardboard cutout and try it.
hey looked at it again....good find....they have undrilled brackets too.
u kno how much they are?
Old Jan 4, 2006
suthrninca's Avatar
Don't know a price yet but my local autoparts store carries them.
Old Jan 4, 2006
Grey's Avatar
DIY King
Those look like they would definately fit. Although the ones without the pre-drilled hole might be better since you can drill out the hole you need to. Our cars are metric, so I doubt that the 3/8" hole will be the right size.
I have the Progress Mounting kit and it's not perfect. It takes up a lof of space. It prevents you from using aftermarket endlinks. It rusts up on you. It's heavier than those simple tabs welded on to the lower control arms. It might move around if you don't bolt it up tight. It has pockets that gather dirt. I might actually get rid of those brackets and go with these tabs.
Good find!
Old Jan 4, 2006
suthrninca's Avatar
Metric, good point. You just covered all of my concerns with the progress mount kit. I'll go by O'Reilly today and check the price.
Old Jan 4, 2006
suthrninca's Avatar
O'Reilly had to order them and needed a min order of $50. However SECO in B'ham can order them by single packs (which contains 4 brackets). The cost per pack is $14.99.
Old Jan 5, 2006
Grey's Avatar
DIY King
If you order the ones without the hole in them and you don't need two of them, then consider selling me two of them. PM me if you want to do that.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
