adjusting koni yellows
Old Dec 19, 2005
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
i have all 4 koni yellows installed on my civic. however, i am having a difficult time fitting the adjusting **** for the rear struts. the metal chassis is blocking my way to fit the **** around the pin to twist. was i suppose to leave the **** on top before bolting everything back up? looks like i have to now use plyers to adjust the rear strut dampers
Old Dec 19, 2005
streetglower's Avatar
yea, just use a pair of pliers and look at the **** to see which way the adjustments go
Old Dec 19, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
It doesn't fit.
Just use pilers, set the shock and leave it alone.
Old Dec 19, 2005
Diablo's Avatar
Diablo is an unknown quantity at this point
I used a rubber malot to bend back the pice of metal that gets in the way.
Old Dec 19, 2005
Zzyzx's Avatar
Autocross Junky
Yup... its not structural or any thing it's just metal that gets in the way.
Old Dec 23, 2005
7thGEN 2nv's Avatar
7thGEN 2nv is an unknown quantity at this point
get some pliers and use it to grab the metal that gets in the way. then twist it back and forth until it rips off. then u should have enough room to fit the adj. ****
Old Dec 23, 2005
jttegx's Avatar
OMNES AD UNUM
so it would be ok to bend the metal sheet back?
i tried plyers, it worked but it was so much of a bitch to get leverage and whatnot. also for some reason, some white lubricant leaked out of the adjusting tip of the strut...smelled like wd-40
Old Dec 23, 2005
Al Gore FTW's Avatar
jdmtytedoridori
i just took some sheet metal snips and cut the piece that's in the way off.
Old Dec 23, 2005
Diablo's Avatar
Yes its ok
Old Dec 27, 2005
ryangt's Avatar
ryangt is an unknown quantity at this point
i ground mine out with a dremel all nice like.
I also made a custom metal adjuster so i can get to that thing with a ratchet instead of climbing into the trunk
Old Dec 27, 2005
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
i just set mine once and forgot about them...all this crazy bendin and cuttin seems excessive.
Old Dec 27, 2005
ryangt's Avatar
i dunno how crazy the bending and cutting sounds, umm a dremel and 5 minites seems pretty good to me. I adjust my shocks all the time, i dont like riding hard all the time ya know, it is a daily driver
also, how can you just set them once and leave them alone?? You dont try to make your suspension better?? Your just content with one setting? what was the point of buying adjustable shocks if your never going to adjust them, seems kinda dumb
Old Dec 27, 2005
varmin's Avatar
i had no problem 'setting them once and leaving them alone'. it was the best setup with the springs. you're just jealous i found my setting and your n00b a$s is stuck 'adjusting'.
Old Dec 27, 2005
ragingSPAM's Avatar
I just burnt my tongue
is it hard to adjust d-specs? with the metal **** they provide?
Old Dec 27, 2005
ryangt's Avatar
haha well my noob *** is adjusting for the track and the street, good luck riding like an old man or a ricer on genero drop springs, ITS CALLED "FINE TUNING" not just set it in the middle and say its ok. Its ok that you dont strive for better in your car, i say the hell with gold, shoot for the silver. a hole
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
beanhead
Sep 24, 2015 12:04 PM
