problem with springs?
well first off im new to the board although i did sign up a while back..anywho had i seen the DIY on installing Springs/struts/etc it probably would have made installing my springs soooo much easier...anywho my question: Has anybody had any issues after installing them? We installed everything correctly, atleast we think, everything is nice and tight and all set in place, but everytime I'm turning slowly (like to pull into a parking space) there is a noise that seems to coming from the springs. We double checked everything and still it keeps making it. any ideas?
If it is a boing or popping then you did not index correctly. If it is metal scrapping then you need to put coil wrap around the dead coils.
first off sorry, thought i mentioned the type of noise....its popping...but have been hearing it less and less so like someone said could just be a need to wear them in...as far as not indexing them correctly, i'll take a look, but im pretty sure it was right. anywho thanx.
reqy
Jun 1, 2015 07:05 AM
vtec_concept
May 24, 2015 10:27 AM
oneheadlight
Apr 29, 2015 11:30 PM
