camber problem HELP. . .
Old Nov 6, 2005
DaSilverCivic's Avatar
DaSilverCivic will become famous soon enough
hey all. . .
i finally installed my spc camber kit. finally after a month sitting in my room. anyways, installation was easy but i have one problem, i'm hearing clunking/thumping sounds from my rear now after hitting certain bumps??? bolts are in and tight although i have not yet gotten my alignment . . . i'm planning to get it this wednesday or friday . . . has anyone had this problem b4? will it go away after i get my alignment??? all the help would be great, thanks
Old Nov 6, 2005
robbclark1's Avatar
Retired suspension supermod.
Are you hitting the wheel well with the tire? Look for gouges in your tires.
You set it so it to the recommended specs right? Does it look like there is more or less camber than stock? If you have more camber and you are too low, you might be hititng the wheel well.
Old Nov 6, 2005
i guess i'm a noob at this. i dnt think my wheel is hitting anything, i looked to make sure there is enough clearance and there is. i put my stock wheels back on for the winter. recomended specs? i didn't know they had recommended specs for the instalation part, i just put them on as the instruction said, i made sure they were the same length both right and left. this is something alignment would possibly be able to fix, putting it on it's recommend specs?
Old Nov 6, 2005
i still haven't gotten my alignment, looks like this at the moment /---\ (/ and \ being the wheels)
when you say wheel wells, you mean the space between the wheel and the car, thus i'm hitting the car rear inner fender part?
Old Nov 6, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Get it aligned. its probably hitting something. If it still makes noises afterwards, go from there.
Old Nov 6, 2005
true, well thanks for the help. should get it done by wednesday or friday
Old Nov 7, 2005
robbclark1's Avatar
Yeah I meant having the arms even when I said specs. And yes I meant the fender well or the fender lip. When I was too low and took turns too fast, my tires would rub against the fender well, putting gashes in it.
Let us know what happens after the alignment. Ask the tech to make sure whether everything looks tightened while he is under the car.
Old Nov 7, 2005
will do. thanks again
Old Dec 3, 2005
alright, i know this is a late reply. been busy with school and work.
got my alignment. good stuff, car looks nice. rides the same though.
noise was reduced. i only hear the clunking noise when i hit real big bumps that are unavoidable. i swang through my friends shop who did the alignment and to take a look at it. i KNOW now what makes that noise . . .
the spc camber kit has a huge NUT that adjusts the camber. well apparently, that NUT since it's so big hits the rear chasis. dude told me that i can/shop can file the chasis down where the nut hits just a bit or i can just ride it out. eventually it'll make a groove and the noise will disappear. well noise is starting to disappear (less noise) and it's making me feel so good. i'm starting to like my car now LOL!!!
well that's and FYI for yah . . . peace
thana
Jun 15, 2020 07:05 PM
brian257
Jun 4, 2015 08:17 PM
bo_red
Apr 23, 2015 10:09 PM
SOHCScreamer
Dec 21, 2001 10:10 PM
RickyRocket
Nov 30, 2001 10:14 AM
