GC's w/ DSPECs or AGXs??
Old Oct 24, 2005
indoyum's Avatar
indoyum is an unknown quantity at this point
I know konis are what people would suggest for Groundcontrols, but I just want to know if there would be any problems fitting the GCs with tokico DSPECs or the kyb AGXs? If GCs fit fine with stock shocks, that means basically anything that is the same size as stock shocks would be fine too?
Old Oct 24, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Konis are the only ones I trust to be firm enough for the spring rates.
Old Oct 25, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i dont see why you'd have a problem putting them on DSpecs. they're replicas of stock shocks/struts. you just have to buy GCs for a 2001-2002.
Old Oct 25, 2005
indoyum's Avatar
so they are replicas of 01-02 shocks/struts. That means I shouldn't buy GC's for 03+ since they are made like the 01-02. Cool, thanks.
Old Oct 25, 2005
Xenin's Avatar
yeah cuz tokico made them with a 50mm housing unlike 03+ which have 55mm housing.
Old Oct 25, 2005
Jap-Euro Fusion
When in doubt buy the shocks, get them, measure them, then buy the GCs. Call GC direct,tell them what you got..... You may need a hybrid kit with 50mm sleeves and 03 upper mounts or some **** like that.
Old Oct 26, 2005
indoyum's Avatar
hybrid kit? you mean GC has applications for a hybrid? Or are you talking about GC having some term with hybrid? I'm thinking that GC should have something that fits tokicos fine especially for tokicos that are meant for an 01-02 civic? Anyways, I'll take your advice boilermaker, just get the shocks first, which I already purchased just today. If I have anymroe questions this thread might pop up again later on. Thanks.
Old Oct 26, 2005
Xenin's Avatar
what he means is that GC will do a custom order. so if say you wanted springs with a different spring rate, they can do it.
Old Oct 26, 2005
indoyum's Avatar
i see, thanks.
hey xenin, did you have to use 01 top mounts for the DSPECs since they are made fore 01-02 and you have an 03?
Old Oct 26, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
let me know, i can get you the D specs or koni's. I think the D specs should work fine and would take less fabrication to put in aka "almost none"
Edward
Old Oct 26, 2005
Xenin's Avatar
Originally Posted by indoyum
i see, thanks.
nope. everything went in no problem.
bobsagator
Nov 9, 2005 02:11 PM
leonhsieh
Sep 2, 2005 12:33 AM
prccivic
Mar 29, 2005 01:04 PM
04RedCiVP
Dec 7, 2004 12:02 PM
Deadkookaburra
Sep 19, 2004 11:06 PM
