alignment settings - what's yours?????
Old Sep 20, 2005
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Okay, im getting my car aligned tommorow, is everyone in agreement that
-1.25 front
-0.75 rear
no toe
that these settings are best for daily driving, with a sporty ride, and some occasionaly twisty curvy roads????
Tell me what you got!
Old Sep 20, 2005
robbclark1's Avatar
Retired suspension supermod.
Front
-2.1
0 toe
Rear
-1.7ish
8th toe in
But i need more than sporty driving
Old Sep 20, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Thats fine for general screwing around.
Old Sep 20, 2005
tfnaaf's Avatar
BLDNPSI Mod
-1.25 front
-0.75 rear
no toe
Will be good enough for 99.9999999% of the people! Its all a matter of how much tire wear your willing to give up
Old Sep 20, 2005
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
I didn't know you can choose....
Old Sep 21, 2005
Zzyzx's Avatar
Autocross Junky
You'd be suprised how much of the cars handling can be tweaked by a simple alignment. only tradeoff really is tire wear....
Old Sep 21, 2005
usafstud's Avatar
Front: -2 degrees
1/8 toe out
Rear: -1.7 degrees
0 toe
perfect alignment for towing a race bike around the mountains
Old Sep 23, 2005
vivid_BLUE's Avatar
make it a habit
so i just walk into a shop, tell them you want an allignment, and give them those settings?
Old Sep 23, 2005
Jap-Euro Fusion
Provided you have the capability to adjust it to the specs you give them.
Old Sep 23, 2005
fuledya's Avatar
Super Member
unless there *******s like Sears, and just "get it within factory specs" after I told them specifically what I wanted, and they didn't. A-holes!!!
Old Sep 25, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
i had -2.5 F
-1.8 R
0 toe all around
rear was 14kg/mm tho and front 10kg/mm had alot of oversteer but i liked it
Old Sep 25, 2005
Jap-Euro Fusion
You can't take your car to the low ball. You tend to have to be willing to pay someone to do it. $44.95 alignments or whatever it is doesn't usually work because you give it to one guy, someone else pulls it in, then 2 other guys do the job. Find Joe Schmo who does it and you can hang out at the door to the bay.
Old Sep 25, 2005
robbclark1's Avatar
or in the driver's seat...
Old Sep 26, 2005
fuledya's Avatar
Super Member
i payed $69 for that alignment.
Old Oct 12, 2005
slicksivik's Avatar
when i put my b&g on i had a toe of -2. haha.
Old Oct 12, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
what would be best for not much tie wear, but also good for handling.
Old Oct 12, 2005
robbclark1's Avatar
8th toe in all around
-1 front
-.75ish rear
Just my 2 cents.
Old Oct 12, 2005
Blahman240's Avatar
with those settings I'd still have good handling?
Old Oct 12, 2005
Blahman240's Avatar
Also, do I need to install the front camber kit? Or is the front suspension easy to adjust without them? They seem kind of useless.
Old Oct 12, 2005
tfnaaf's Avatar
BLDNPSI Mod
The only factory adjustment is toe frt and rear, if camber needs to be adjusted then you must buy a camber kit to make it adjustable
Old Oct 12, 2005
john_817's Avatar
john_817 is an unknown quantity at this point
what about caster? would the camber kit adjust caster also?
Old Oct 12, 2005
Jap-Euro Fusion
No. Caster isn't adjustable. I know of one set of camber plates that allow caster adjustments, but I've never seen anyone buy them, I believe you have to import them from australia.
Old Oct 12, 2005
tfnaaf's Avatar
BLDNPSI Mod
^^ is correct and rarely does caster go out of spec and if it does caster isnt a main tire wearing factor. It's more for stability than anything else. If there is a HUGE caster difference as in more then .5 degrees from side to side then most likely something is bent and needs to be replaced.
Old Oct 13, 2005
slicksivik's Avatar
got mine done today..
front L -0.01 Right -0.01 camber
rear L -0.5 Right -0.9 camber
i have both front and rear spc camber kits and its lowered over 3 inches.
Old Dec 29, 2005
jdm_veloz's Avatar
jdm_veloz is an unknown quantity at this point
mine is
0 front
-1.5 rear
is it good?
Old Dec 29, 2005
Zzyzx's Avatar
Autocross Junky
Originally Posted by jdm_veloz
mine is
0 front
-1.5 rear
is it good?
Camber like that will be fine for putting around the street...but push it a little bit and you'll see understeer city. Great for keeping you safe, suxors for cornering.
Got an alignment finally (rather then a DIY aligment) so I have actual #'s now...
-2.6 camber Front with 1/16th toe out on the nose.
-1.6 camber Rear with 0 toe.
Old Dec 29, 2005
robbclark1's Avatar
How the hell did you get -2.6 with toe out? Didn't you run out of tie rod around 2? You suck!
Old Dec 29, 2005
Jap-Euro Fusion
Rob I could to it too, but I stopped. Maybe your car just sucks.
Old Dec 29, 2005
fullgrown's Avatar
<---- I am really this short in person!
fullgrown is an unknown quantity at this point
i got a quick question about alignment...got my alignment couple months ago from the dealership...don't they align the back also? cause my rear tires are getting worn out on the inner part. i thought when i go there and ask them to align my car, they'd do all, not just the front. am i wrong? or you can't align the back? i just have springs with stock shocks...
Old Dec 29, 2005
Jap-Euro Fusion
well unless you have a camber kit, they can't do much to help it.
They can fix the toe, but severe camber is still going to eat tire.
twd000
Oct 4, 2015 12:52 PM
JMKendrick
Sep 16, 2015 06:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
BryanM.
Aug 29, 2015 03:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
