Neuspeed Strut Tower brace
Old Sep 13, 2005
prccivic's Avatar
I layed it down in the engine bay for a check on how it looks, and it is not very close at all to fitting? DO you think they sent me the wrong part? The holes are like 1in-2in off if i line up the passenger side?
Old Sep 13, 2005
SLO REX's Avatar
250+ awhp Stage 2
Umm you have to jack up one side of the car and loosen the strut and then it should fit. I had the same problem. They are made to be tight.
Old Sep 13, 2005
nick_95673's Avatar
nick_95673 is an unknown quantity at this point
yup i had to shove mine on to fit. just make it fit.
Old Sep 13, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Ding ding!
It doesn't work unless it fits like a glove. Sloppy fits have no tension --->no stiffness
Old Sep 13, 2005
prccivic's Avatar
ok....and in the instructions is says 2002-up " Bend clutch reservior bracket forward as nessasary to clear tie-Bar. NOTE: bend bracket down if A/C hose touches bottom side of tie bar"....my deal is that the bar is pushed hard up against the fire wall? Is that normal?
Old Sep 13, 2005
prccivic's Avatar
Ding ding!
so u reccomend a rubber mallet in the install?
Old Sep 13, 2005
nick_95673's Avatar
if you cant get it on with elbow grease jack the car up to release the tension.
Old Sep 13, 2005
WEAPON-R CIVIC's Avatar
WEAPON-R CIVIC will become famous soon enough
mine isnit that tight on the firewall, have a 01, diddn't bend clutch bracket, relocated it
Old Sep 14, 2005
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
im with boilermaker on this one if it don't fit don't force it because you could end up breaking something and end up paying for that to get fixed, just exchange if for a different one and see if that one fits or not. better in the long run
Old Sep 14, 2005
my05civic24's Avatar
Ace Ventura
my05civic24 is an unknown quantity at this point
My neuspeed front upper strut tower brace fit fine. I love mine
Old Sep 14, 2005
prccivic's Avatar
boilermaker was not saying that it doesn't fit..he was telling me that its supposed to be tight because if it was an easy fit..it wouldn't be a strong part
Old Sep 14, 2005
Jap-Euro Fusion
You need to jack up the front end just like the neuspeed directions say to. When you do, lots of stuff moves around and the bar should fall in with a little wiggling. If it has directions for the 2001+ civics then 99% of the time you got the right bar. It is a tight fit, it will not go in with the car on the ground. I can't see it being 2" off, but there will be one hole that will not go unless you lift up the car and push a little but. DO NOT use a hammer of any kind, you'll mash the strut hat threads.
Old Sep 14, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
It's against the fire wall, sounds like it's backwards, it should go infront of the intake.
Old Sep 14, 2005
SLO REX's Avatar
250+ awhp Stage 2
Umm wrong. It goes behind towards the firewall.
Old Sep 14, 2005
manahoonie's Avatar
mine fit fine WITH the car on the ground. yes, i placed my bar across to see how it looks. you should notice that the strut bolts are angled in slightly, so that when you line up the bar on top of the bolts, it will be slightly off, but if you place it such that the bottom lines up, it should be closer to perfect. putting mine on, we did it with the car on the ground, and just had to nudge one side of the bar (hit it with my hand) and it popped on in (probably because of the slight angle).
Old Sep 15, 2005
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
^^ Mine worked the same way. It was tight but I just had to pop it with my hand and then bolt everything down. No problems at all. I cannot imagine it being 2" off!
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
