Once again K20 Swppers
Okay so i got my car back!!! Boy does it have some GO GO juice now! lol. Anyways i took it in to get an allignment today and everything except the passenger side CASTER was good. So bassically im wondering if anyone else ran into this problem? *01 k20A Civic pulls to the right* If there is any sollution for it? Let me know.
The only real way you can change the caster is crash the car.
The swap didn't cause the issue.
Caster doesn't change without a caster plate. Its the angle of the shock front to back. The "lay back" angle of the shock if you will.
It also won't make the car pull, it can change the steering response to an input, but not cause a drift.
Your toe makes the car pull, camber can also make the car pull.
Well i checked all my numbers on the car, and they are set to the stock limits. But on the Invocie i got, i said "Right Side Caster Can not be changed, Car will pull to right" i can type out all the numbers on the sheet that i got with the alignment.
Autocross Junky
(Sorry, hit the edit button rather then the quote....)
kenji4861
Dec 29, 2002 01:55 PM
Freshguju
98
Nov 11, 2002 10:09 AM
