Less BOUNCE to the OUNCE
Old Aug 6, 2005
MitzysMan's Avatar
MitzysMan is an unknown quantity at this point
Hi Guys, I know this is a kinda common issue. But how can I get my Stock 2005 LX to quit bouncing in the back ?
One person said better shocks would do it ? Right now the ride is really stiff - still having a hard time getting used to it - kinda regretting my purchase.
Would better shocks stiffen the ride more (which I don't want) or will it calm it down. The front doesn't botter me to much but when I hit and bump in the road (one that dips vs is raised), the back end just seems to lash down and then bounce up.
And the car generally bounces on the highway.
thank you
Mitzysman
Old Aug 7, 2005
MitzysMan's Avatar
If I have someone put after market shocks on the rear does it void the warranty on my car in any way.. I only have 1000 miles on it.
I guess I was thinking about Tokico's but I can't seem to find them in sizes that fit 2005's
Old Aug 7, 2005
information's Avatar
information should not be trusted
are u zapp ????? or roger . anyways i think that bouncing is all in your head it cant even be that bad .
Old Aug 7, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
the car will be kinda bouncy anyway. the shocks may help a little, but dont expect a lexus ride (or even an accord ride) in a civic. with the tokicos, the same shocks for the 04 should fit the 05.
Old Aug 7, 2005
jttegx's Avatar
OMNES AD UNUM
transport more weight... seriously. put some luggage or few pounds in the rear and it'll soften the ride quality.
if you plan to invest into a stereo sub system, nows a good time as well lol.
Old Aug 7, 2005
drew22mader's Avatar
There is gl@ss in my @SS...
No way is it as bad as my friends celica on bags, i swear, we were driving and i would hit a bump and barely feel it and when i would look back his car would be bouncing up and down for about 2 or 3 seconds after he hits the bump, very funny. Just get a different setup, aftermarket shocks shouldn't void any warranty.
Old Aug 8, 2005
aznpoopy's Avatar
aznpoopy is an unknown quantity at this point
check with the dealer.
some state that any modifications instantly void the factory warranty on the car.
other manufacturers are more lenient and will do work on the car under warranty as long as any aftermarket parts did not contribute to whatever issue you are taking the car in for.
Old Aug 8, 2005
MitzysMan's Avatar
thanks guys !!
Old Aug 8, 2005
legally they have to prove that the aftermarket part is what caused the damage before they decide not to cover it. meaning a suspension modification wont make your engine warranty void.
Old Aug 8, 2005
my local Honda dealer is really nice, they didn't care about my drop on the car, i bet next yr when i hopefully get the turbo they won't say much about that either, as long as I can get a new oil pan so that i can put the stock one back on if i should ever want to trade it back in or something bad really happens that i need to take the car back in. Oh yea, did i mention my brother is the Sales Manager there?
Old Oct 11, 2005
MitzysMan's Avatar
Hi Guys, took the advice to add some weight... put 120 lbs in the back (Salt) ... helped the bounce but seems to slow me down some and the rear dropped about 1 inch... took 40 lbs out and it seems to run better acceleration wise but a little of the bounce/firmness is back
what does weight making the ride less bouncy and softer tell me ? Could I duplicate this with firmer shocks ... guess I'm a little confused b/c i thought the springs would get stiffer the more they are compressed ? Lower=stiffer ?
Old Oct 11, 2005
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
jttegx is right, add more weight in the trunk, that will ease the bounce.
You can also keep your gas tank full. $$
I put on aftermarket shocks, KYB, they calmed the bounce, or really eliminated it. KYB offers GR2 and AGX for the Honda civic, but, I dont know if they have a version to fit civic 2005.
Old Oct 11, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Weight is like a damper. Your complaint is the shocks react too fast (hence rough ride), making them push harder slows them down. Nothing will make it softer, I suggest letting the car break itself in.
Old Oct 11, 2005
from what i can tell it seems that our cars just have a bouncy nature. you can get it to ride better with the weight in it, but its never gonna ride smoothly.
Old Oct 11, 2005
My Tein SS coilovers gave me the best ride i've felt from my car, STOCK, then i went with NEUSPEED SPRINGS W/ TOKICO BLUES and now the TEIN SS. I have my damper set on 12, so its kinda soft.
Old Oct 11, 2005
01redJDM's Avatar
01redJDM is on a distinguished road
I knew u were gonna mention that
Old Oct 12, 2005
MitzysMan's Avatar
Your Ride is sweet! The local place in town said Tein SS are nice too.
Can you tell me how both of those setups compare to stock ? IE Bounce, Harshness, etc. What advatages and disadvatages do those 2 setups have over stock ?
thank you very much
Old Oct 16, 2005
MitzysMan's Avatar
burp
Old Oct 18, 2005
Well with stock i had stock hubs and tires, which was a smooth ride since it was made for the car. I then went with different wheels and the ride became less comfortable and you could feel the road and bumps more. I lowered it on Neuspeed Springs and Tokico blues and the ride improved from just the tires and stock suspension. But whenever i installed the Tein SS's it was like night and day, i immediatly felt a difference driving, since then i have the setting at like 12-14 depending on what i'm doing. The ride is very nice and its not bouncy, the car evens out fast and the cornering has improved too, i also went with a front strut bar, but that doesn't seem to do ALOT. I was expecting much from it. I would highly recommend the Tein SS cause (1) You are able to adjust your ride height, i currently have my front lowered down to about 4 threads left, and there is no gap in the front, i have the rears with about 13 threads left, only because my stereo weighs the rear down alot. (2)The ride is alot better, you can adjust the stiffness you want (3) Tein is a great brand and you can't go wrong with them
Old Oct 18, 2005
MitzysMan's Avatar
thank you for the great info !!
Sep 26, 2023 06:44 PM
Bruce2
Sep 21, 2015 08:01 PM
MamaBear2015
Sep 15, 2015 09:35 PM
breanna_17
Jul 21, 2015 04:01 PM
txtadik
Feb 12, 2003 11:19 PM
