Stripped Bolt
Old Aug 2, 2005
matt86's Avatar
matt86 is an unknown quantity at this point
Stripped Bolt
I was trying to install my strut bar and accidentally stipped one of the bolts. How can i get it off now? Remember i only have a limited space to work because its the bolt in the back. Thanks
Old Aug 2, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
did you strip the threads on the bolt or round the head off? if its the head get a vice clamp or compression pliers and turn till the bolt comes out if its the threads do the same but work it back and forth on each stroke. depending on how bad its stripped it might come out easily or you might have to die tap it out. but thats probably not possible with the limited space....
Old Aug 2, 2005
matt86's Avatar
It was just rounded a little bit.... I finally got it off though after giving it some hell. Thanks
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
