tein flex coilovers
Old Aug 1, 2005
jayjdlc's Avatar
jayjdlc is an unknown quantity at this point
tein flex coilovers
hi! i have a civic coupe 04 with tein flex coilovers. it has squeeking noice whenever i a bump on 30 mph but when more the 40mph, i dont hear any noice. what do you guys think is the problem? thanks in advance.
Old Aug 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
We can't solve intermittent problems. There's no "it must be this" to intermittent issues. Thats why its intermittent.
Check and make sure everything is tight, all the bolts, the lock collars the nuts on the tops of the pillowballs.
If they have dust boots, check to make sure they're not rubbing on something, the springs are seated properly and theres no dirt somewhere there shouldn't be dirt. Most people who are willing to drop $2000 on a set of coilovers also have the know how and ability to troubleshoot their own problems.
Old Aug 1, 2005
dru106's Avatar
ThE CoRRupToR
WTF!!??? Why the hell are you going over bumps at 30+mph??
Old Aug 1, 2005
Da1lyDr1ver's Avatar
when my friend got his tein SS, it make a clunking noise. but it turned out he needed some top mounts or something and the problem went away. (i dont know the exact answer because he took it to a shop)
Old Aug 2, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yeah, what the hell?
$1700 suspension @ 30+mph speed bumps =
Old Aug 4, 2005
tamazoid's Avatar
tamazoid is an unknown quantity at this point
i got the flex also, and mine squeeks in the front sometimes... mostly when i'm changing it to go stiffer... i think it just need to get used to the setting first and then it would eventually go away...
also, i don't drive over bumps that fast!
Old Aug 4, 2005
Jap-Euro Fusion
Where the hell did you guys get "speed bump" He said BUMP. I presume to be a normal bump in the road. I hit track curbs at 80, thats a bump, but not a speed bump. You can hit a bump as fast as you want as long as the suspension has enough travel and stiffness to take it.
Old Aug 5, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
sorry if this is a little off topic guys, but I didn't want to make a new thread for it ... but ...
does the Tein Flex come with upper pillow mounts?? ... I noticed the SS coilovers have an option, but the Flex's don't seem to come with that option. I have an 02 civic ...
Old Aug 5, 2005
depotcivic's Avatar
depotcivic has a spectacular aura aboutdepotcivic has a spectacular aura aboutdepotcivic has a spectacular aura about
damn........$1700 ...........yo u must have some money just lying around or u tightwad...
man! makes me wanna think about spending 600
Old Aug 5, 2005
tamazoid's Avatar
i think all flex should come with the pillow ball upper mounts... atleast for our civic application it does...
Old Aug 11, 2005
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
Exclamation Clacking and popping noise from front steering arms
I have the flex coilovers and i have a problem when i turn the wheels. At slow speeds when the wheels are turned nearly all the way left or right, a loud popping/clacking noise is generated. I think it is from the steering arms but i'm not sure. I have a few ideas, but i want to see what you guys think first.
Old Aug 12, 2005
tamazoid's Avatar
i have that noise too... but i think it's just the spring moving... someones was talking about it before...
Old Feb 2, 2007
bluedot's Avatar
bluedot is an unknown quantity at this point
to answer the original question the squeking noise you hear is coming from the rear springs. Its the sound of the spring coils touching. Also mine were alot louder until I broke them in. Tein sells a rubber piece u can install to help reduce noise. Someone else had metioned steering noises. Lowering your car is going to make the tie rods to short because of the increased angle they now sit at. Adjustable /longer tie rods will eliminate this. i believe js racing makes them for 7th gen civics. i just cant afford them yet, around $300. Hope this was helpful!
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
