ran into problems with my neuspeed x-brace
Old Jun 27, 2005
hassanperryon's Avatar
hassanperryon is an unknown quantity at this point
I installed my x-brace but ran into a wierd problem, everytime I rev my engine to 6000 rpm and let go of the pedal,my engine makes a wierd scraping noise? did I tighten the bolts too tight or did I not even tighten them enough? I didn't use a torque wrench but I think I torqed the bolts to 76 lb with my foot?
It also sounds like its my transmission, I don't know? thats why i'm here.
thanks
Old Jun 27, 2005
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
Check if the exhaust is rubbing it or something else coming in contact with the brace. I had no problems putting mine in. There is about 1/2 inch clearance between the pipe(OBX header, OEM cat, 2.5in midpipe, OEM muffler) and the bar.
Old Jun 27, 2005
I looked under my car and it's my exhaust thats hitting the brace? thanks for the help.
Old Jul 1, 2005
ren808's Avatar
ren808 is on a distinguished road
if you are planning to get the progress sway bar combo you might run into the same problem as well.
Old Jul 3, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
no they redesigned it to not be an issue with aftermarket exhausts
Old Jul 5, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
the progress sway bar's bushing mounting bracket has to be cut for clearence of the bolt's that go in the sub frame.
usajags84
May 30, 2015 06:49 PM
DouglasTheGreat
May 27, 2015 11:23 PM
Rogelio Rey
May 24, 2015 08:30 PM
dragonsblood
Apr 27, 2015 12:28 PM
EuroCivic
Dec 7, 2001 12:56 PM
