tie rods
Old Jun 19, 2005
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
tie rods
anyone got the part number for the oem tie rods? also are there any aftermarket tie rods that can be used on our cars?
Old Jun 19, 2005
civicvtec1ps's Avatar
Search and Learn
J's racing makes full tie rods ends.
$260
Old Jun 19, 2005
^got a link for that?
Old Jun 20, 2005
Search and Learn
http://www.ephatch.com/forum/showthread.php?t=69170
Supposed to eliminate clicking noise on low drop.
Not sure it will be worth $260..
Old Jun 20, 2005
streetglower's Avatar
thats alot of money for tie rods.
Old Jun 20, 2005
robbclark1's Avatar
Retired suspension supermod.
www.hondaautomotiveparts.com
My question is WHY do you want aftermarket tie rods? What is the purpose unless you want to run more than -3 degrees of front camber, aftermarket tie rods won't do much.
Old Jun 20, 2005
one of my tie rods has play and i want to replace them. also my tie rods are frozen and it is very difficult to adjust. i just wanted to know if there are a better alternative than the oem ones.
Old Jun 20, 2005
wonderz's Avatar
wonderz is on a distinguished road
i would say just stick with oem ones.
what do you mean by has play? is the boot busted?
and what you mean by frozen? if you mean its "locked" onto the steering bar, then its normal.
Old Jun 21, 2005
well i hit a nasty bump in the road a while ago. i check the front end of my car and the left front wheel has some side to side play. so when i drive the car feels a little loose when i turn. also both of the lock nuts on the tie rods are so rusy and frozen that i have to heat up the nut to get it loose. its a real pain when i have to do an alignment on my car.
Old Jun 21, 2005
Treellama's Avatar
Treellama is an unknown quantity at this point
Hey, you're Don's little brother! I used to work with him... I think we met at his wedding.
Anyway, I had my tie-rod ends replaced a couple weeks ago because of the exact same symptoms (plus the nasty clunking sound when you turn sharply at low speeds). I couldn't keep it aligned and I wore the front tires bald. Now it handles tight and steers true, and it's actually fun to drive again. So yeah, OEM tie-rods are awesome.
Old Jun 21, 2005
ya im dons bro. ya im goin to order some oem ones prob next week. im goin to have one hell of a time replacing the old ones.
Old Jun 23, 2005
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
how do you tell when a tie rod is done? I mean when do you know it's time to change it
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
