Hard hits
Old Jun 18, 2005
Jesjr's Avatar
Jesjr is an unknown quantity at this point
Hard hits
HI guys,
I recently just adjusted the height of my rear ground control coilovers up and for some odd reason the back passenger spring makes hard hitting noises for every bump I go over. It seems to be getting worse. Any suggestions? Thanks much.
Old Jun 18, 2005
jttegx's Avatar
OMNES AD UNUM
need more details. describe what the noise sounds like, at what speed, other suspension mods that could affect this, etc.
Old Jun 18, 2005
tamazoid's Avatar
tamazoid is an unknown quantity at this point
maybe the nut on the top of your shock is not on tight...
Old Jun 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Yeah, details. If you raised them, unless you're still on stock shocks, you shouldn't be hitting the bumpstops. What it might be is the poly seat that ground control supplies, it doesn't fit in the shock hat very well. Just a thought, but we need more info.
Old Jun 21, 2005
Jesjr's Avatar
I still have my stock shocks on, I had the springs on for a year and a half, and it never made the noise. I took off the tire and turned the spring to adjust the height. Now every bump i go over at 20mphs or more sounds like large rocks hitting metal. Did I adjust them incorrectly? Is their more to it than just taking off the tire? Thanks
Old Jun 22, 2005
skipbarber's Avatar
did you raise or lower? if you lowered it, the nut on the top mount probably came loose since the spring is under less compression.
burnyd
ECU Fried
May 24, 2018 10:44 PM
adamdrives
15
Aug 8, 2015 08:53 PM
Jul 12, 2015 11:54 AM
