Ground Controls With Tokico D specs
Old Jun 13, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
Anyone no any info about putting GCs with D-specs? Its 1 am and no one is open to call, and i need to make decision. Can u put any year GC with D-specs? Etc, thanks
Old Jun 13, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i dont see why not. there's only a handfull of people on this site that have d-specs so cant really say. mine are going on later today with neuspeed sports. i would think since d-specs are just like replicas of our stock shocks/struts + dampening adustability it should be fine. you'd just have to confirm with GC what part number you need cuz they got 3 part numbers + specific ones for koni. probably 01-02 since thats what d-specs are for, but i'm putting them on my 03.
Old Jun 13, 2005
SevenCyrus's Avatar
So there are diff GCs? And with the D-Specs, do you have to drill 16mm for 04 models, or did it come with a bushing or somthing?
Old Jun 13, 2005
Xenin's Avatar
03+ are all 16mm holes.
Old Jun 13, 2005
SevenCyrus's Avatar
yea, but some companys know this and send somthing so u can convert. Am i going to have to drill?
Old Jun 13, 2005
dj02's Avatar
when you order them did u specify what year your car was? i know tockico has made the adjusments for 03+ you just have to tell them wich year your car is. and yes the gc's will be fine with the d-specs. let us know how it rides with them on. did u get the stock gc spring rates?
Old Jun 13, 2005
ojay's Avatar
ojay is on a distinguished road
yea, for GCs there's different applications for 01, 02, and 03+ civics, and each has koni or non-koni applications as well.
i'm going to assume that the d-specs are 14mm and need to be drilled out for 03+ users to 16mm, unless tokico fixed this problem by now (with a conversion sleeve). might want to call them up to be sure.
Old Jun 13, 2005
SevenCyrus's Avatar
Ok then, so the main question is, what GC do i get? 01-02? Since D-Spec are 01-02?
Old Jun 13, 2005
ojay's Avatar
since you have an 04, get the 03+ GCs, and get the d-specs mount holes drilled out (if needed, call tokico)
Old Jun 13, 2005
SevenCyrus's Avatar
but if the stut of the Dspec is made for 01-02, then wouldent it make sence to get GCs for 01-02?
Does it even matter?? Since im swaping the whole strut out?
Old Jun 13, 2005
PoorCollegeBoy's Avatar
Stolen digital camera = no ninja picture for me
PoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the rough
To confirm- YES you do need to drill out several holes on the Tokicos for the 03 and up Civics. I had to take mine into a local machine shop and pay them 40 dollars to drill out larger holes for me.
Old Jun 13, 2005
SevenCyrus's Avatar
its just 4 holes, 2 on each front strut(well 8 if u count other side). All u need is a 16mm drill bit, a drill press, etc. Its a DIY.
Old Jun 13, 2005
The drill press I have wasnt large enough, and no one I know has one, so I just wanted to let people know that.
Old Jun 13, 2005
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Even if you are getting the 01-02 GCs, you need to get the correct one specific for your car. 01 and 02s have different uppermounts. So what you need to know is the D-Spec shocks outer diameter, what uppermounts your car has(ball bearing or not) and the crash bolt size to prepare for drilling(14 or 16mm). Call GCs and provide them with the first 2 info. That should be sufficient for them to know what you need.
Old Jun 13, 2005
SevenCyrus's Avatar
So you mean to tell me if i buy used GC's that where specs for an 02...they wont fit on the D-specs for my 2004? This sucks.
Old Jun 13, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Correct. Be careful when buying used things with limited info. If they are not for your year they wont fit. Hit us up if you need a new set.
Edward
LorenzoC0395
Jul 14, 2015 08:46 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
Jul 12, 2015 11:54 AM
