Suspension problem
Old Jun 8, 2005
jta's Avatar
jta
jta is an unknown quantity at this point
Suspension problem
Basically I lowered my car using H & R springs with 1.5" drop all-round, this was last summer so exactly one year. This is on stock struts.
Problem:
Recently noticed when going over pot holes, uneven road there is this cluck noise only from the front driver side wheel.
Please tell me what are the possiblities for this noise?
Thank you.
Old Jun 8, 2005
es2k2's Avatar
Proud to be a civic owner
the bearing plate might need to be replaced?
it seems like it's the same thing i have...
but the mechanic said it shouldn't have anything to do with the springs.. it's just the freaking design by honda...
Old Jun 8, 2005
jta's Avatar
jta
How much does it cost? and did your problem go away?
Old Jun 8, 2005
es2k2's Avatar
i'm getting it fixed this weekend hopefully
my mechanic ordered it for me for $30.. install is going to be $50....
he told me there's a recall for that, but i called honda and they said no.. you can give it a try
but i'm not sure if you have the same problem as me...
Old Jun 8, 2005
flotsamm's Avatar
Could be the bearing or just something lose.. I'd make sure everything is tighten to spec before swapping parts out.
Old Jun 8, 2005
PunkingCivic's Avatar
I need TP for my bunghole
see if the strut bolts in the engine bay are tight
It could be a blown strut too.
edspyhill09
Jun 12, 2016 02:45 PM
reqy
Jun 1, 2015 07:05 AM
oneheadlight
Apr 29, 2015 11:30 PM
