Ss, Ssp, Flex
Old May 30, 2005
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Ss, Ssp, Flex
Im looking at the product info for these TEIN full coilovers and it apears that only the flex set-up allows you to adjust ride height w/o compressing the springs, right?
How do these set-ups hold their height with only 1 locking perch? Do they ever move on you?
My Hayame's allow me to adjust ride height w/o compressing the springs, I thought TEINS had this feature as well?
Old May 30, 2005
robbclark1's Avatar
Retired suspension supermod.
SS and SS-P have the same spring rates (6k/8k), except that the SS-P has a pillowball upper mount. A pillow ball is basically a metal ball with the mount attached to it. The stock mount uses a rubber grommet so you can imagine that the pillowball is a lot stiffer than the stock mount. However, they make a LOT of noise when hit hard.
Tein flex has stiffer spring rates (12k/14k) and better valving. They have three locking perches so you can adjust the height without changing the spring length.
If you want better coils, stick with the SS. If you want more adjustability, then get the SS-P. I wouldn't suggest the flex unless you plan on autoxing/road racing.
Old May 30, 2005
fuledya's Avatar
Super Member
Thanks Rob, is it tough to remove the stock pillowmount?
After my bad experience with my Hayame's im pretty nervous and cautious about forking out more money for a different set-up. Im still not sure what I should get though. What's peoples opinions about Tein SS vs B&G S3's? Has anyone ridin in cars with each set-up to compare?? Or is that like asking "which exhaust is best"......
Old May 30, 2005
robbclark1's Avatar
why would you want to remove the pilloball? I am not sure how difficult it is becuase I don't see why you would want to.
I have been in a car with the SS and it was comfy. If you want a set it and forget it suspension then get some konis with some good springs.
And yes you are basically asking "what suspension is best" and we can't give you that answer. Good tuning is a black art that takes many hours, much frustrating and much money. Just because I have dropped X amount of money on my suspension doesn't mean that nothing will go wrong.
Old May 30, 2005
fuledya's Avatar
Super Member
the tein ss's you have to use the stock mount, is that hard to remove?
That's what I meant.
Old May 30, 2005
goodtimes's Avatar
hey i have B&Gs onn my car and i half to say i love them i dont know how low you what to go but lower that any other full coilover out there, the ride is so smooth its like ridein on air and it handles good to.
B&G is all so comeing out with a new coilover called the rs2 is 32way adjustable and the ps2
Old May 30, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
SS-P! all the way! ^_^ i love them
Old May 30, 2005
§C§H§O§C§O§B§O
B&G's have helper springs...i bet the ride will be MUCH MUCH more like stock than the teins
Old May 31, 2005
pbfoot's Avatar
what do you mean better coils = SS? if the flex has stiffer spring rates, wouldnt that be better performance-wise? maybe the question should be what the drop is for? is it for performance improvement or for appearance mostly and he wants to keep the stock ride quality?
from what ive read, im leaning more to the flex's, but i have a miata, so it could be different. my last setup was stock shocks w/ neuspeed springs, and i really didnt like the feel of a lowered car w/ reduced shock travel/compression distance. naturally this would not happen as much if i had konis or other aftermarket shocks, but i think i would still prefer to keep my height adjustment separate from my shock compression adjustment. once i get them im not planning on changing them unless something breaks...so if i decide to start racing and doing auto x (which i havent gotten around to doing so far) i might need a fully adjustable setup for that and street driving. just my $.02
Old May 31, 2005
tamazoid's Avatar
tamazoid is an unknown quantity at this point
I have the Tein Flex in my Civic... And you only need 1 locking perch for the stroke adjustment because you have to turn the whole asembly to change the stroke and you use the 1 locking perch to make it stay...
Old May 31, 2005
robbclark1's Avatar
Uh, I am completely confused by your post. I never said anything about the SS being a better coil....But i agree with what you have to say
Old May 31, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Helper springs don't do anything when the car is on the ground. Their sole purpose is to keep the spring seated if the corner lifts. They contribute nothing to the ride, infact if you look up there with the car on the ground, they're probably damn near fully compressed.
Old May 31, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
BG's in stock PM us if you need more info . Tein is a great choice as well. Have installed them on customer cars and both serve great at what they do!
Edward
Old May 31, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Go with ksports, I got them and they are great. Ksportusa.com
They allow you to adjust height without adjust travel, because of their helper spring. The new ones even have an adapter so they fit 01-03 and 04-05. I think U can get them for about 900 shipped. They are easy to install and the ksportsupport is very helpful. That his aim by the way, I can't hurt to drop him a line and talk to him. I love my ksports and so far the have handled very very well...I'd tell u more into detail but I'm busy right now...soo I'll post more info if you want
Old May 31, 2005
tamazoid's Avatar
Doesn't helping springs also contribute to a more comfortable ride by eliminating some of the pre-load? Cause I drove my friends 2000 EJ Civic with Tein RA Coilovers which has the helper springs and it's pretty comfy going over small bumps on the road but it's stiff as hell when you take hard turns... But the turn in is kinda slow because of the helper springs.
Old May 31, 2005
if yer gonna go with the ss's, spend the extra money and get the ss-p's.. that's what i did.. i got the ss-p's and i love 'em
Old Jun 1, 2005
truehonda's Avatar
BG are 899 Shipped like the K Sports and are well known and German made. They are not re-branded Taiwan Based suspension.
Old Jun 1, 2005
Boggie1688's Avatar
Diamond Member
Dood....why do you always do that?! I find it totally uncalled for you to run around and talk trash about other products. I'm just telling him what I think is a good product. This is like the 2nd or 3rd I've come around and you told me k sports are crappy *** coilovers, and that they are rebranded taiwan coilovers.
1. You never held the coilovers in your hands, so you really can't compare the quality can you?
2. You don't even know if they are rebranded, they could, they couldn't know...how do you know?
3. Its very unbusiness like to go around bashing other people products and promoting yours at the same time.
4. I own the god damn coilovers, are you trying to offend me?!
Old Jun 2, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
if you dont know the differences dont buy flex.
i have flex and i love it.. but if u dont understand why they do what they do youll never be able to adjust them and set them properly
its a triple perch setup compared to double
GolNat
Nov 27, 2018 03:32 PM
elitezdc5
May 26, 2015 05:46 PM
timpan
May 18, 2015 07:06 AM
HondaLuver
Jul 24, 2003 12:57 PM
chocobo15_2000
May 28, 2003 02:44 PM
